Old 05-29-2006, 09:34 AM   #1
outlawchevy
outlawchevy's Avatar
turbo 400 wire ?
hello i pulled the motor and trans out of my 69 350/400 the wire that plugs in the side of the trans buy the speed cable where does the other end of it plug in thanks for any help
(If all else fails get a bigger hammer)
outlawchevy is offline   Reply With Quote
Old 05-29-2006, 09:48 AM   #2
uncle
Re: turbo 400 wire ?
Should be a switch behind the carb.
uncle is offline   Reply With Quote
Old 05-29-2006, 11:07 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Yep, a switch on the carb, and if you were dealing with a 71 & up, it'd be on the throttle pedal.
Old 05-29-2006, 05:17 PM   #4
outlawchevy
what kind of swith does any one have a pic and the name of the switch thanks for all the help
Old 05-29-2006, 08:32 PM   #5
Fred T
Cantankerous Geezer
Fred T's Avatar
I think it's called a throttle kickdown switch. The mounting varied, depending on the year, engine and carburetor. I'm putting up a pic of mine, but the bracket has been modified to fit on a Holley carb. This switch works with the vacuum modulator determines when your tranny downshifts.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 05-29-2006, 08:36 PM   #6
JimKshortstep4x4
Since you have a 69, the TH 400 "Kickdown Switch" will look like the one in the picture which is mounted to the rear stud of the carburetor on the Q-Jet.
There are only two wires hooked to the switch; a power wire and the wire from the detent switch on the transmission. The wires are yellow in the picture.
Jm
Old 05-29-2006, 09:19 PM   #7
qksilver
Uncle did you ever find that switch and wiring?
qksilver is offline   Reply With Quote
Old 05-30-2006, 12:42 PM   #8
Fred T
Cantankerous Geezer
Fred T's Avatar
If you don't have the switch or bracket, the best option besides trying to find used is to replace the pedal and linkage from a 71-72. This puts the switch inside the cab and gives you a throttle cable instead of the rod linkage.
Fred
Old 05-30-2006, 04:51 PM   #9
Longhorn Man
Except that you'd have to cut a section of the firewall out of the 71/72 truck in order to do that.
There's aftermarket solutions for this problem.
Old 05-30-2006, 11:55 PM   #10
outlawchevy
does any one sell the switch that bolts to the carb
Old 06-01-2006, 09:48 PM   #11
stope4
Most Camaro dealers sell the bracket. Dealers like Rick's First Generation, Classic Industries, D&R Classic, etc... They may even sell the solenoid plunger.
stope4 is offline   Reply With Quote
Old 06-01-2006, 11:04 PM   #12
KFreddy
Active Member
KFreddy's Avatar
I believe Lokar makes the switch.
KFreddy is offline   Reply With Quote
