Old 05-29-2006, 08:59 PM   #1
wazooz2424
good deal???? 69 c10
1969 c10 short bed. great paint job, few minor rock chips in clear coat. 3sp on the column inline 6. 130k original miles. all original stickers/plates. all electrical components works except for fuel gauge. wanted 8000, he will accept 7200. light blue with white roof.
here is the only problem found. occassionally the column shift lever sticks. on the column where the linkages are under the hood. it stuck once on test drive going from 3rd to reverse. all i had to do was jump out, pop the hood, and flip the linkage over. after that, it shifted fine the rest of the drive.
have any of you encountered this? is there a simple fix? maybe an adjustment or bushings? thanks a bunch!
wazooz2424 is offline   Reply With Quote
Old 05-29-2006, 09:09 PM   #2
kansas city cheyenne
Rebuilding 1 at a time
kansas city cheyenne's Avatar
Re: good deal???? 69 c10
seems alittle high to me. Just my opinion.
71 cheyenne lwb
383 stroker
2004R tranny
Factory ps, pb, air
http://smg.photobucket.com/albums/v3...t=101_0059.jpg
66 Nova SS L-79
327
m21
http://smg.photobucket.com/albums/v3...t=101_0042.jpg
kansas city cheyenne is offline   Reply With Quote
Old 05-29-2006, 09:14 PM   #3
wazooz2424
also, keep in mind that i live in maryland when figuring price. i realize that you have to keep zipcode in mind when considering prices of vehicles. also has had power steering installed.
Old 05-29-2006, 11:46 PM   #4
Green Machine
Green Machine's Avatar
That is usually an easy fix, there is an adjustment, slotted cam type adjuster at the bottom of of the column, loosen the little bolt and turn the cam to remove slack between the shift arms and then oil it a little. This will prevent the shift selector from going in between the shift arms. I'll bet hundreds of trucks have been converted to floor shift just because of this one simple adjustment.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
