05-29-2006, 10:07 PM | #1 |
Still Green but learning
134a question
Does the refigerant come with oil already in it?? Since my conversion I have blown a clutch and when we put a new clutch on the A6 the compressor started Locking up.... should I add oil and refirgerant or go ahead and replace the 30x yr old compressor?
-- Cory 71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab 07 Suburban LTZ 4x4 2010 Acura TL 98 Mastercraft "FrankenStar" 225 27253 UPS/USPS IIOY....nope never was |
05-29-2006, 10:26 PM | #2 |
Re: 134a question
go ahead and replace the compressor put new oil and refirgerant dont forget to repalce the dryer reciver with you change the compressor
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
05-29-2006, 10:50 PM | #3 |
Re: 134a question
you always need oil in the system
some 134 you can buy with the oil added to it, you will need to find a chart to know how much to add may the forch be with you |
05-29-2006, 10:57 PM | #4 |
67-72 Addict!
Re: 134a question
I thought it had 1 ounce in it but I might be wrong. I have about 50 cans on hand, I can check tomorrow.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
05-30-2006, 05:54 AM | #5 |
Re: 134a question
According to the manual, oil is added to the system as follows:
Repaired compressor......7 fl oz Replaced evaporator......3 fl oz Replaced condenser.......1 fl oz Replaced rec/drier..........1 fl oz Jim |
05-30-2006, 10:17 AM | #6 |
Re: 134a question
Thanks Jim,
So if I replace the Drier, and compressor, then I need to add 8fl oz of oil to the system along with the Coolant? Also about how much 134, From what I have seen on my searches this varies.
05-30-2006, 10:20 AM | #7 |
Re: 134a question
BTW, for the record, I had someone do my 134 conversion, thinking that I did not want to release the freon. They were the ones that I think left the oil out, awfully conspicuous that the compressor would startlocking up after the conversion.
O well, there is 300.00 (after everything is fixed) I will never get back. Funny part is I was over there a few months ago and saw him doing another conversion, he just blead it off with no vaccume just Like I would have..... Any job worth doing... Anyone in the Mebane NC area that is looking to get something like this done PM Me so I can warn you.
-- Cory 71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab 07 Suburban LTZ 4x4 2010 Acura TL 98 Mastercraft "FrankenStar" 225 27253 UPS/USPS IIOY....nope never was Last edited by phlegm; 05-30-2006 at 10:21 AM. |
05-30-2006, 08:31 PM | #8 |
Re: 134a question
The amount of R-12 recommended for the system is 3 lbs 4 fl oz for trucks, (Burbs with the rear AC is more). 80 percent of the R-12 capacity seems to be a good starting point (approx. 2 lbs 10 fl oz) but we have had to add a little sometimes.
I would be curious about what others have experienced. Jim |
06-01-2006, 09:56 PM | #9 |
Re: 134a question
10 - 11 oz of oil is about right. Put half in new rebuilt compressor suction side and half in dryer. Freon put about 2 16 oz cans in with system running. Place thermometer in passenger side vent, turn ac to full blast, close all doors. Start adding a little more freon at a time checking the thermometer with rpms at about 1500. Continue repeating these steps recording the temperature each time. Keep adding a little freon at a time until thermometer starts reading a higher temperature than the previous reading. Then release a little freon until you start getting the lower temperature. This is the amount you want. Too much freon or oil will cause your system to blow less cold.
