Old 05-29-2006, 10:14 PM   #1
jamon8
jamon8's Avatar
73-87 3/4 ton lower arms on a 69 1/2 ton
Can I put a 73-87 3/4 ton lower control arm on my stock 1969 1/2 ton crossmember.
If so what kind of modifications will I have to do?
jamon8 is offline   Reply With Quote
Old 05-30-2006, 11:04 AM   #2
jamon8
jamon8's Avatar
Re: 73-87 3/4 ton lower arms on a 69 1/2 ton
bump
Old 05-30-2006, 11:10 AM   #3
Aarons72s
Are you trying to convert the half ton to 3/4 ton? If so I think yes but if it is to use a 3/4 ton arm on a 1/2 ton to convert to 3/4 ton spindles. But not for using half ton spindles. The hole for the ball joint is larger in the 3/4 ton a-arm than the 1/2 ton. i hope this helps.
Aarons72s is offline   Reply With Quote
Old 05-30-2006, 01:09 PM   #4
jamon8
jamon8's Avatar
ok I think that I am not simplifying this enough
WILL A 73-87 3/4 TON LOWER CONTROL ARM FIT ON MY 1969 1/2 TON CROSSMEMBER.
lets not get overly technical about what I am doing although I appreciate the concern. this is all I need to know
Old 05-30-2006, 08:51 PM   #5
Aarons72s
Simple Answer: YES
Old 05-31-2006, 08:38 AM   #6
jamon8
jamon8's Avatar
thank you
after reading my message I sounded a little snouty but sometimes all a guy wants is an response to the original question.
I am putting 89 spindals on my 69 and I need to put 3/4 ton lowers on. I have read all the posts but no one mentions all the possible solutions to the problem to broaden the possibilities.
Thanks again.
Old 05-31-2006, 12:14 PM   #7
Aarons72s
No problem and good luck.
