Old 05-29-2006, 10:43 PM   #1
f.monroe
f.monroe's Avatar
700R4...What year is best?
I am thinking of putting a 700 in my 77 Chevy and was wondering if there were certain years to look for or look away from ? Thanks , Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 05-29-2006, 11:13 PM   #2
bigblock73
yeller
bigblock73's Avatar
Re: 700R4...What year is best?
I have always heard the 87 and newer units were the best, and to stay away from the earlier years.
Bowtie Overdrives has a lot of good info on these transmissions, and seem VERY knowledgable on them...might try giving them a call just to pick theri brains.
bigblock73 is offline   Reply With Quote
Old 05-29-2006, 11:51 PM   #3
1badbowtie
Also Painless Wiring sells a converter lock up kit to retrofit your non ECM vehicle, and its only around 80 bucks.
1badbowtie is offline   Reply With Quote
Old 05-30-2006, 02:29 AM   #4
DroppedZ84
DroppedZ84's Avatar
Yep, 87+ I THINK they changed the sun gear and that's what made them stronger. I know they ARE stronger, just can't remember exactly why.
But then again, if you get an empty case and put ALL new internals in it...it really doesn't matter now does it?
DroppedZ84 is offline   Reply With Quote
Old 05-30-2006, 12:03 PM   #5
Jonboy
Slots go on anything!
the early ones had weak pumps, and those are the ones that gave the early OD tranny's a bad rep. I think by 87 they had everything sorted out. I know in the 88 and later light truck applications had an auxillary valve body to help when towing.
1974 Jimmy- 5.3/4L80e/NP241
Old 05-30-2006, 02:15 PM   #6
SSC's76
No No
SSC's76's Avatar
It's actaully 88+. Late 87 (MIGHT) have the aux valve body like the 88 but there are a few minor improvments that were not introduced until 88. If your planning on dropping a rebuilt one I suggest Probuilt. Dana is a real nice guy and does great work. They even have 4L60's converted to vacuum modulator operation so no screwy TV cables or electronics to mess with except for the TCC lockup which the S series vacuum switch can be had for $20 at your local GM dealer. The vacuum scwitch is mucho easyer and cheaper then the painless or B&M kit.
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 05-30-2006, 05:48 PM   #7
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Ditto on SSC's76 post. 88-92.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 05-30-2006, 07:30 PM   #8
SanitysBane
Thats when they went from 700R4's to 4l60's, then in 93 when they went full electronic they became 4l60Es.
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 05-31-2006, 04:46 AM   #9
the baron
the baron's Avatar
Hi all ,
I've also heard that there are two kind of TH700R4 :
one with 27 splines , the other with 30 splines ...
it seems the 27 splines is a PITA to get pieces to overhaul / rebuild / repair ...
I have no idea if this all is true or false ...
Anyway , I don't bother , I ditched my TH700R4 for a TH400 , less problems or no problems at all ...
gretzzz
the Baron
1982 Suburban 2WD , 260ci Olds engine,TH400 , will get a 1979 front clip , might be ready in ... 2016
1985 Chevy Van ( 305/350 ) , "Kellogg" equipped , my actual D.D.
1960 Girl Friend , frame still good , body has some dents
the baron is offline   Reply With Quote
Old 05-31-2006, 11:36 AM   #10
bodydropped
i got a 90 caprice cop car trans in my truck im runnin a b&m lock up module to lock it up around 60 but not sure what years are the best but when i rebuild mine im usin a corvette kit because there are more clutchs
bodydropped is offline   Reply With Quote
Old 06-01-2006, 12:14 AM   #11
f.monroe
f.monroe's Avatar
Thanks for the info . I think I will look for an 87 , or newer trans and give the old truck a little relief . Frank
