05-30-2006, 08:48 AM | #1 |
13lazers' blazers
tilt column?
i have a column shift/ tilt steering column that was installed in my 2wd 1970 blazer. i think its a converted van column based only on the newer hazard light switch. it fit without any problem. my buddy has a 1965 c-10 with a factory 283/ 3 on the tree combo. my blazer was a 250/ 3 on the tree combo originally. we are thinking about an even trade, i want to make my blazer like original, and my buddy has an extra th350 lying around. are the steering/ tranny setups similiar enough to swap between a 1965 and a 1970 without any major "customizing"? i dont want to cut or weld, otherwise i have all the hardware and wires necessary. can anyone offer any suggestions? thanks
1970 2wd blazer 1972 1ton blazer 4x4 in progress 1966 mustang coupe (modified) 1985 c20 suburban tow rig 1996 462 ranger with a 150 efi merc. a former B.A.S.S. tournament boat almost all exempt from california smog laws intentionally. |
05-31-2006, 02:50 AM | #2 |
Re: tilt column?
If you have a straight plug at the end of the column harness it's a Van tilt. If it is a half-moon shape it's a truck tilt. Van tilts are also a couple inches shorter, you look up that info in the FAQ's
Best to check the length of the 65 column setup, the whole column is shorter than 67-72 stuff if I'm not mistaken. I just pulled one from a 66 but it was a floor shift type. Last edited by Americanrider; 05-31-2006 at 02:51 AM. |
05-31-2006, 04:43 AM | #3 |
its all about the +6 inches
Re: tilt column?
replacement turn signa; switches will have the straight plug and later hazzard button. Shaft length is the only way to really tell.
05-31-2006, 07:36 AM | #4 | |
Re: tilt column?
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
