advantages of the 72 doors?
What are the advantages of having the 72 doors with the screw? Does it hold the vent window tighter or make it easier to install? I am redoing a set 67-71 doors for my 72 and they need that spacer to be re-welded and i was wondering if i should try to just cut that piece from the old 72 doors.
Thanks Tim |
Re: advantages of the 72 doors?
The screw in the 72 doors helps keep the bracket below the wing window from cracking. I have messed with both 72 and on the 67-71 doors almost everyone of them the support bracket had cracked in half. I am useing the older doors on my orange and white. I am just planning on welding the tabs back together. If I was going to spend that much time with the screw I would just buy new 72 doors. I hope this helps.
So are the bracket welded together on the 72? I figured it was done to make the vent window install easier by allowing you to pull the panels apart.
![]() Join Date: Nov 2004
the bracket should be one piece, it should look like a square "U." I bought new doors for my truck and I got the '72 doors. Once I had the windows in I put a screw in and it pulled the door together just enough to get a nice seal around the window bottom and door.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
Thanks for the replys. I think I am going to cut that out of my old 72 doors and put it in the 67-71 doors since i need to make some repairs in that are anyway.
