Old 05-30-2006, 06:48 PM   #1
jay_shy
SWB 4X4 CLUB
jay_shy's Avatar
power steering ?
I am in need of a steering coupler/rag joint. I have a 68 4X4, that the PO put power steering on. Does anybody know the GM part number I need? What is the going price for these things? And finally, should I go for a new one or ask for a used one on the parts board? Is there anything else I should know before I buy one?
Jason
jay_shy is offline   Reply With Quote
Old 05-30-2006, 07:02 PM   #2
mbgmike
Re: power steering ?
Someone here will have one. last one I bought at a junk yard was $20.00 . I don't think you will have much luck buying a new one from gm. I never have. I think they run about $45.00 from some companies
mbgmike is offline   Reply With Quote
Old 05-30-2006, 07:43 PM   #3
zeeklu
I got a new one (GM) from Wes at Classic Heartbeat. http://www.classicheartbeat.com/ Chris
zeeklu is offline   Reply With Quote
Old 05-30-2006, 08:22 PM   #4
shifty
Questionable
shifty's Avatar
i have a rag joint in my garage i'm not going to use. you can buy them at the "Help!" section at any auto parts store for cheap - like less than ten bucks
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 06-03-2006, 04:34 AM   #5
4x4Poet
Over the years, I bought two whole, new, 71/72 4x4 steering couplers that included the rag disc. One from LMC and one from GMCPauls. Both were the same repro part made in Taiwan. Both splined hubs on them needed to be spread to get them on the steering gear without destroying the splines or having to hammer on them and risk damaging the steering gear internals. Both seemed fine, otherwise.
Oh, both came with a coupler-to-steering-gear-shaft, hex headed retainer bolt instead of the GM style 12-point headed bolt. The 12-point bolt better allows a socket in the tight confines. I simply reused the original 12-point bolts.
Next time, I'll investigate what GM still offers. Last time I checked, just the rag disc thru a dealer cost more than a whole repro coupler. Hopefully, ya still get what ya pay for thru GM on this.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
