71 Chevy
power steering conversion
I am new to this site but have seen a lot of helpful hints. I just bought a 71 C10 with manual steering. I was wondering what all is needed to convert it to power steering.
I bought a power steering gear box and will be buying a pump and brackets. Just wondering if the splines off the manual steering shaft are the same. And also in the length of the steering shafts the same. I am assuming that it is a bolt on swap. Thanks for any input |
The LuvShack Garage
Re: power steering conversion
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
71 Chevy
hi,
thanks for the reply, do you have any tips for the swap job? |
The LuvShack Garage
IIRC, The shafts are the same, make sure you buy new lines, using used
ones will just give you headaches, might be more info HERE somewhere ![]()
71 Chevy
thanks
Welcome aboard boot. It should a bolt up. Watch the routing of the lines, be sure they don't rub on the lip of the inner fender and get cut.
Born To Lose Club
![]() Join Date: Feb 2003
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
Brian Smith ![]() 1969 Chevrolet K10 LWB Fleetside - Proud Owner For 20 Yrs - 1 of 208 Built & Sold In Canada! - 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's. 1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 2 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds 2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 15 Yrs - 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's. 2008 Yamaha Raptor 700r - Proud Owner For 13 Yrs - ITP Mud Lites. 2015 John Deere 1025R - Proud Owner For 6 Yrs - 24HP Diesel/H120/54D/260B/SB1154. |
71 Chevy
Thanks a lot that was the info I was lookin for.
Gone Fishing
Welcome to the board from Texas
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop ![]() 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
Designated A-hole!
Welcome to the board from South Mississippi!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
MooMoo
Welcome to the board!
'97 ext 4x4 3" body lift and 7'6" Fisher MM2 '04 Polaris 700 twin EFI **sold 2-1-07** '07 Polaris 800 twin EFI Stealth Limited Edition Support the Board! Or deal with me foo! ![]() Its all fun and games till you find out shes 16. ![]() |
RIP Mr Ron
![]() Join Date: Dec 2005
Welcome to the board from West Tennessee. Good luck with the power steering swap. I don't think it's to hard.
Ron (Mr Round Tuit) ![]() Be kinder than necessary, for everyone you meet is fighting some kind of battle TN Message Forum TN Facebook Group SETN Truck Show My Photobucket |
#13 |
Happy to be here
![]() Join Date: Mar 2000
Weclome to the forum Boot85. I moved your post to the 67-72 discussion area in hopes it would get a better response....
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 06-20-2006 at 08:15 AM. |
#14 |
Junior Member
I personally went to the boneyard and got everything off of a 75 c10 350 pump hoses brackets and gearbox and pitman arm. You may have to grind away a little of the front bumber bracket and even smaller amount from the radiator mount bracket as the gear boxes from the later trucks are longer, that is of course depending how similar you truck is to a 67. Hope this helps, oh yeah depending on your water pump where the bracket mounts to it i had to drill out the threads in the well as the bracket i used had a nut on the rear arm. This all cost me about 95 dollars the old hoses were serviceable.
#15 |
Semi-Senior Member
You will need a different pitman arm because the lower splines are bigger than the manual box.. I believe the input shafts are the same.
The pump mounting has to be for a short waterpump, if you have a V-8 and want it origional style. Find a donor to make it easier.
'68 50th Anniversery LWB Custom Fleetside, '77 305 v-8, turbo 350, factory speed alert (still works), '71 drivetrain w/front discs. Some call it ugly yellow, others call it Ochre '83 Jeep CJ-7, <80,000 miles, original owner '04 Chevy Suburban, 4x4, 2500, 6.0 ltr, Predator Diablo programmer '95 GMC K1500 Extended cab |
#16 |
71 Chevy
I actually used a gearbox off a 78 chevy 2WD and it was a direct bolt on. I did however find a pump off a 72 C10. The one thing that I learned is when you have a system full of air, take the cap off and fill it up. Put cardboard underneath the truck and a rag around the pump, then start the truck and work the steering wheel then shut it off, at this time when the air comes to the top it will overflow. Just repeat a few times until the air seems to have worked its way out.
I found this out the hard way and made a mess. FYI..if you leave the cap on during this process it will really make a mess.
71 C10 72 C20 62 Chevy II 2DR HT |
