Old 05-30-2006, 11:56 PM   #1
robsm88
robsm88's Avatar
throttle cable for GenIII swap
Just wondering if someone that has done the swap could tell me which throttle cable works. Probably going with a Lokar. I am sure I could figure it out, but I thought someone could save me some time and make sure I get the right one..
robsm88 is offline   Reply With Quote
Old 05-31-2006, 12:07 AM   #2
shifty
Questionable
shifty's Avatar
Re: throttle cable for GenIII swap
stock cable worked fine. the stock truck cable for the 01-02 will be just fine, it reaches the pedal and even hooks up properly to the 71-72 pedal (don't remember what year your truck is). with you using the 6.0 intake, it should have the truck fastener on it already to pin the cable down properly.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 05-31-2006, 12:10 AM   #3
shifty
Questionable
shifty's Avatar
i don't have part number for stock cable for a '00 silverado thorttle cable whicis what i used but is and cost me $21 from gmotors.com, which, by the way, is the absolute most pleasant GM parts site on the web to use - and you get parts at 20-40% less than the dealership.
Old 05-31-2006, 12:44 AM   #4
robsm88
robsm88's Avatar
Thanks Shifty!! I have a 71' and my 6.0 has the truck linkage.
Old 05-31-2006, 10:17 AM   #5
shifty
Questionable
shifty's Avatar
you should literally be able to use the stock cable then - should be a direct boltup. i got the truck cable and it works with my LS1, i only had to flip a bracket to make it mount in the intake manifold for the camaro - you have the truck manifold on yours, so should be direct boltup.
you need pictures or anything of my setup and how long the stock truck cable is? i'll be happy to snap a couple for you. i have a 68 so my pedal will be a little different. i'm using stock linkage and stuff.
Old 05-31-2006, 05:02 PM   #6
blazerboy72
I used the lokar hi-tech or whatever they call it on mine. It worked flawless also and added a little bling under the hood.
blazerboy72 is offline   Reply With Quote
Old 05-31-2006, 05:15 PM   #7
shifty
Questionable
shifty's Avatar
i didn't want to pay the $$$, i'm already spending too much on this as it is.
Old 05-31-2006, 07:41 PM   #8
robsm88
robsm88's Avatar
Thanks, what length did you guys use? I don't want to come up short.
Old 05-31-2006, 07:45 PM   #9
blazerboy72
I ordered the longest one and then trimmed it.
