Old 05-31-2006, 08:36 PM   #1
Flat 67
Junior Member
Flat 67's Avatar
Pics of Big Block in I-6 location wanted
I know a lot of discussion has gone on about BB motor mounts, but I would like to see how close to the firewall a BB would be. I know a SB almost hits the firewall but will a BB even fit in the I-6 location. I like the rearward look and I am willing to cut/modify the firewall if necessary. Pics would sure be appreciated. The BB is going in a 67 C-30.................Thanks, Flat 67
Flat 67 is offline   Reply With Quote
Old 06-01-2006, 01:42 PM   #2
Olden Days
Living In The Past
Olden Days's Avatar
Re: Pics of Big Block in L-6 location wanted
I think Yukon Jack modified his firewall for a bigblock 4x4 in the rear mount location. anyhow to the top for ya neighbor
Olden Days is offline   Reply With Quote
Old 06-01-2006, 08:02 PM   #3
GMC71k20
it would take a big hammer
GMC71k20 is offline   Reply With Quote
Old 06-01-2006, 08:50 PM   #4
Flat 67
Junior Member
Flat 67's Avatar
Hey Olden, Thanks for the ttt.......Flat 67
GMC71k20, thanks for the suggestion ,but that will be my last resort........Flat 67
Old 06-01-2006, 09:15 PM   #5
farmtruckIII
71 GMC 454/TH400
farmtruckIII's Avatar
you will get alot of smart ass commnets, I got crucified on here for using SB frame stands swapped side to side to kick my BB back.
"The bigger you are the harder you fall, the farther you walk the longer you crawl."
farmtruckIII is offline   Reply With Quote
Old 06-01-2006, 09:40 PM   #6
Flat 67
Junior Member
Flat 67's Avatar
farmtruckIII, were you successful in your rearward BB installation?..........Flat 67
Old 06-01-2006, 09:40 PM   #7
GMC71k20
if your really serious about doing this in a 2wd then look into the corvette valve covers with the indent for the mast cylinder. i think youll save yourself some headaches by moving it forward though. since mine is a 4x4 mine will be way far back but im going to help it by using a small body lift and a little hammering.
Old 06-01-2006, 11:09 PM   #8
farmtruckIII
71 GMC 454/TH400
After alot of cursing I was lol. It was a pain to get it square but it is there and running.
Old 06-01-2006, 11:11 PM   #9
farmtruckIII
71 GMC 454/TH400
It also sits up fairly high that way, there is a good 4-5" between the c-member and the oil pan, kinda gives it an old school look.
Old 06-02-2006, 02:49 PM   #10
TP from Cntl PA
TP from Cntl PA's Avatar
Farmtruck, that appears to be the same way that they put the 454 in my K-20..............Wasn't too bad of a job IMO, other than they hacked a hole for the header pipe in the driverside tower, if they'd have added some round tubing to the back side it would have been a slick setup.
Don't know about yours, but mine was rubbing on the firewall with the big distributor they had on it.....................
Can't really tell you much more, I pulled the BBC and all associated parts from that truck.
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck
'71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel!
'69 3500 GMC 305V-6/4spd, Still under reconstruction..........
Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!!
TP from Cntl PA is offline   Reply With Quote
Old 06-02-2006, 06:06 PM   #11
farmtruckIII
71 GMC 454/TH400
I should have done that as well, but I dimpled my header tube a tiny amount instead, I can get a .175 feeler gauge in there and that's about it. I have no dist problems at all there is about 1/2 an inch or so there.
Old 06-02-2006, 07:03 PM   #12
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
I just took a 396 out of my swb 4X4 and put a 350 in it's place in the same spot the big block was. No differansce that I noticed. The only clearance issue was the bigblock headers hit the motor mount stands and the smallblock did not. Sorry I have no pics of this.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 06-03-2006, 02:17 PM   #13
Flat 67
Junior Member
Flat 67's Avatar
Thanks for all the responces guys, got some good ideas and I'll forge ahead with my project..............................Flat 67
Old 06-03-2006, 04:09 PM   #14
Olden Days
Living In The Past
Olden Days's Avatar
I was thinking Yukon would see this thread and post it himself but if you didnt check out his webpage, then here it is. Brouse through it . He has that killer truck in there somewhere. http://yukon.b0xen.us/
Old 06-03-2006, 05:26 PM   #15
Flat 67
Junior Member
Flat 67's Avatar
Thanks Olden, Yukon does have a nice website with lots of pics that will help me.................Flat 67
