Old 06-01-2006, 12:25 AM   #1
outlawchevy
outlawchevy's Avatar
blazer tank in truck ?
will a blazer tank hang to low with a 3/5 drop in a 69 lb truck thanks for all the help
(If all else fails get a bigger hammer)
outlawchevy is offline   Reply With Quote
Old 06-01-2006, 06:07 AM   #2
GMCPaul
Re: blazer tank in truck ?
it'll be about 4" higher than the bottom of your rearends pumpkin and have about 10" clearance between it and the ground, you'll rip holes in your oil pan up front or tear off a exhaust pipe, damage a a-arm etc.... before you'd hit tank while driving forward, only way to hole a steel one would be to back up into something, and the poly tank is flexible enough to give some before you could puncture it. In my opinion you would have to be a very bad driver to rip one open, they'll never get close to touching just driving down the road.
GMCPaul
GMCPaul is offline   Reply With Quote
