Old 06-01-2006, 12:28 AM   #1
sbc383rulz
sbc383rulz's Avatar
trans swap??
i have a 69 lwb c25 2wd gm performance 383/375 with a 4 speed truck trans (465 i think) and a 4.10 D60 im getting a 3.54 D60 from a friend and want a OD manual anybody got any suggestions as to which trans would hold up in this heavy old FAST beast??
rice is best served smoked
sbc383rulz is offline   Reply With Quote
Old 06-02-2006, 07:16 PM   #2
sbc383rulz
sbc383rulz's Avatar
Re: trans swap??
it really dosent even need to be a 5 speed i just want something i can speed shift taking off at the strip is fast but every shift i lose ALOT of time with the truck 4 speed.i want to make the 1/4 mile time decently fast and still have a fun truck to drive and not just a drag truck any help is appreciated greatly
Old 06-02-2006, 11:45 PM   #3
71chevytruckguy
71chevytruckguy's Avatar
Re: trans swap??
could get a 4 spd saginaw or munci. hurst makes a shifter for both of the transmission if you put them in a truck. got a 4 spd saginaw in mine with the hurst shifter in it and love it. chris.
its a work in progess.
71 c-10 lwb, in the middle of frame off restoration.
69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump.
7.807 @ 88.37mph 1.60 60FT
80 g-20 van, tow rig, cammed 305, th350, 10 bolt
88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's
71chevytruckguy is offline   Reply With Quote
Old 06-03-2006, 12:37 AM   #4
Green Machine
Green Machine's Avatar
Re: trans swap??
Search the forums for A833 and maybe MY6. Myself and others have posted about it. Gm had a 4 speed overdrive from about 81-86. I think they are great.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
