06-01-2006, 12:49 PM | #1 |
Polyurethane cab mounts
I have a 1970 c-10 4x4 and the rubber cab mounts have just about had it. Just wondering if it would be better to polyurethane mounts would be better.
I am confused why it says it is a c10 and it is a 4x4. shouldnt it say k10. |
06-01-2006, 01:59 PM | #2 |
Re: Polyurethane cab mounts
The poly mounts are much stiffer and will not flex as much as the rubber. If your looking for a comfortable ride use rubber. ( The poly mounts will last longer ) Look at your VIN tag it should start with a K if nobody has swapped the cab or tag.
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
06-01-2006, 07:10 PM | #3 |
does the fender emblem say C/10? there was no "K" emblem, except for the K5 blazer. so if you have a plain jane truck with no trim packages, it will say C/10 even though its 4wd.
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
06-01-2006, 10:43 PM | #4 |
Ooh was ebaying at school today had my work done.....and was wondering why it had these huge 4x4s as c-10s I thought it was owner neglegence....guess not
Shane
1993 K1500 350 5 speed 1985 K10 Silverado Vortec 406 5 speed (in body shop) "I been drivin' this '85 pickup truck Them buddies of mine call it a bucket of rust She's a little beat up but she still runs like the wind Yeah, kinda like me I been banged and bruisedBeen around the block a time or two But I'm runnin' like new goin' places I never been No, I ain't broke I'm just broken in" 1963 Dodge Townwagon(its amazng what 30 years and zero miles will do to a vehicle ) Member#20327 |
06-02-2006, 01:21 PM | #5 |
yes it says c10 on the fender and to tell you the truth I have not even paid att. to the vin #. But when I order parts I should order for a k10?
06-05-2006, 12:33 PM | #6 |
The rear cab mounts will vary between a C-10 cab, and a K-10 or all heavy model cabs. Check you're cab to make sure of what you're ordering if you have any doubts...
IF I recall correctly, K & heavier the rear cab is on the outside of the frame rail, and the C-10's are on the back of the cab, on the inside of the frame rail... I might have this backwards... |
06-05-2006, 12:48 PM | #7 |
when ordering cab mounts i have always been told to order cab mounts for the frame,not the cab,,i put a 2 wheel drive cab on my k-10 frame so i ordered mounts for the k-10 frame..
