06-01-2006, 03:31 PM | #1 |
engine removal Q
I’m I going to need to remove the trans cross member if I try to pull the engine and tranny out as one unit? Can I get away with just unbolting the tranny from the cross member and leaving the cross member in place?
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
06-01-2006, 06:01 PM | #2 |
Re: engine removal Q
That cross member bolts up to the Tcase. I think you could leave the crossmember and Tcase in place. There is a 6" spline or so on the back of the Tranny that needs to slide out of the Tcase though. That may take some massaging.
Rob "RunTMCfan" |
06-01-2006, 06:04 PM | #3 |
SKINNY TIRES RULE!
He has a 2wd blazer -
I've pulled engine/transmission combos from cars before without removing the cross member. You may have to pull the grill/radiator/radiator support though to get enough clearance. It might be easier to pull the cross member. I'd ask on the general message board since your rig should be the same as the 2wd pickups.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
06-01-2006, 07:41 PM | #4 |
maybe someone can move my thread. I don't want to double post the same stuff.
06-01-2006, 08:23 PM | #5 |
Oops...didn't notice (2wd). Sorry.
Rob "RunTMCfan" |
06-02-2006, 12:10 AM | #6 |
FYI. you don't need to take out the crossmember to get the motor out. The motor and tranny made it out fine. Next up... more power and air.
