Green LED's installed in dash tonight.
Just installed green LED MATRIX bulbs tonight. What do you think?
![]() ![]() Two B9's for the heater controls and four 194's for the instrument cluster. These are not my cup of tea. These would look really sharp with white face guages. ![]() ![]()
Photo Gallery of 1972 K/5 Blazer CST Last edited by Green Monster; 06-02-2006 at 11:00 AM. |
Re: Green LED's installed in dash tonight.
Here is the new B9 and the old the B9.
Photo Gallery of 1972 K/5 Blazer CST Last edited by Green Monster; 06-02-2006 at 02:26 AM. |
Nice I Like the look, Where did you get the leds from?
Big difference.
Do they dim the same as a regular bulb? Might edit the bulbs for sale in this section though... ![]() |
FormulaFire- I bought these on ebay. Here are the two listings.
B9 1895's & 194's VTBlazer- These LED's dim exactly like a normal bulb.
Photo Gallery of 1972 K/5 Blazer CST Last edited by Green Monster; 06-02-2006 at 10:53 AM. |
SKINNY TIRES RULE!
Did you have to do any wireing modifications?
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
The only wiring modifications that had to be made were little wires that are on the 194 light bulb where they insert into the into the socket. These bulbs are the push in wedge style. The wires on the bulb did not meet up and had to be bent and moved to ensure contact was made. Once that was done, they worked perfect.
Photo Gallery of 1972 K/5 Blazer CST |
![]() Join Date: Apr 2004
I thought wiring mods had to be made for LED tail lights, is that true. If so, why no mods for this?
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
What kind of wiring mods are you talking about?
The only mod for LED tails, as far as I know, is to install a no-load flasher. LED's don't draw enough current to make a normal flasher... well, flash.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
MooMoo
looks good I like it
'97 ext 4x4 3" body lift and 7'6" Fisher MM2 '04 Polaris 700 twin EFI **sold 2-1-07** '07 Polaris 800 twin EFI Stealth Limited Edition Support the Board! Or deal with me foo! ![]() Its all fun and games till you find out shes 16. ![]() |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Looks pretty good... Need to get me one of those no load flashers though my leds still dont work right..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#13 | |
I attempted to dim the dash last night without success. When I attempted to dim the dash lights last night, the bulbs were either ON or OFF. I found you cannot dim the dash lights if you have swapped all your incondescent dash lights with LED's. You need at least one incondescent bulb in a dimmable socket for the LED's to dim. I thought the LED's were dimmable because I dimmed the dash lights after I intalled one LED and it worked. I did this several times during the installation. Apparently, I did not try this when I swapped out ALL the bulbs. I did not like the look, so I removed the LED's. Oh, by the way, do not start your truck with the oil pressure gauge disconnected. I'm sure many of you already knew that. What a friggin mess I have on my carpet. I would have been really livid if I did not have new carpet on the way. I was sitting there, at night, with the truck running looking at the dash lights. I was on the fence about leaving the lights in or taking them out, So had them dash partially installed. When I opened the door to hop out the under dash lights shined on the pool of Quakermud 10W40 located infront of the pedals The reason I even moved the truck was because my house A/C water collector/remover stopped working which resulted in a swimming pool in my garage. I was a little peaved since I had two messes to clean up.
Photo Gallery of 1972 K/5 Blazer CST Last edited by Green Monster; 06-04-2006 at 08:24 AM. |
