How to remove heads from a 350
I got a small block 350 and im trying to take the cylinder heads off because the bolts are really on there. Any good ways to take off the bolts?
thanks in advance |
Re: How to remove heads from a 350
Hi and welcome from South TX.
I used a 1/2" drive 5/8 impact socket, it's stronger than a normal socket, a short extension and a looong pull handle. I think I even had to use a cheater pipe to break 'em loose. Lube all that up with a big can of elbow grease and your in business! ![]() |
Well, a 1/2 or 3/4 breaker bar with a long piece of pipe will most likely do it. Might try an impact wrench too.....
1/2" imact gun with the 5/8" impact socket, if that doesn't break em loose, use a long handle 1/2" ratchet with a pipe extension. worst thing that'll happen is a broken bolt, or the socket will slip off the head and your knuckles will hit the rockers or something.
#5 | |
![]() Shane *Disclaimer: Use my suggestions at your own risk ![]()
1993 K1500 350 5 speed ![]() 1985 K10 Silverado Vortec 406 5 speed (in body shop) "I been drivin' this '85 pickup truck Them buddies of mine call it a bucket of rust She's a little beat up but she still runs like the wind Yeah, kinda like me I been banged and bruisedBeen around the block a time or two But I'm runnin' like new goin' places I never been No, I ain't broke I'm just broken in" 1963 Dodge Townwagon(its amazng what 30 years and zero miles will do to a vehicle ![]() Member#20327 |
its all about the +6 inches
Wow... I've never needed tools that HD for a simple head job. I normally use a 3/8 breaker bar, and if need be, I'll grab the 1/2 inch. If I'm actually with my tools at work, I use my 3/8 impact.
