Old 06-02-2006, 08:02 PM   #1
shelby987
shelby987's Avatar
WHERE was he hiding/nesting and how did he get out?
I haven't been working on my truck for about a week now...and I live in the country....well, when I went out to my back yard to do some work on my truck I opened the drivers side door and a mouse fell out from underneath the dash (approximately in line with the radio). Where was he hiding/nesting?
Also, he ran under the seat of the truck, after a few revs of the open header exhaust he was spooked enough to get out of the truck...but he popped out from underneath the truck.....I have been under my truck MANY times, and there are no holes in the floor under my seat.....so how did he get out?
1969 SS 350 Camaro Sold 2008
1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's
1980 Chevy Malibu 2 dr Sold 2007
1993 Olds. Cutlass Ciera Wagon Traded 2006
2003 Saturn L200 w/5pd. D/D
My list spans 5 decades with One common thread.....GM!
shelby987 is offline   Reply With Quote
Old 06-02-2006, 08:23 PM   #2
Green Machine
Green Machine's Avatar
Re: WHERE was he hiding/nesting and how did he get out?
I think they have some kind of dye you can put on the mouse and then use an ultraviolet light to see where the mouse leaks out.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 06-02-2006, 08:34 PM   #3
rage'nrat638
rage'nrat638's Avatar
where theres one theres more maybe the vent hoses.
they really like making a nest out of padding, then they have there little babys..got a cat?
good luck on this one. hope you get this under controll fast
rage'nrat638 is offline   Reply With Quote
Old 06-02-2006, 09:05 PM   #4
JAKES 68GMC
Aluminum slot wheels rule...
We found 5 mice in a closed and sealed outboard just a awhile ago, and we still can figure out how they got in there.
JAKES 68GMC is offline   Reply With Quote
Old 06-02-2006, 09:18 PM   #5
shelby987
shelby987's Avatar
I am hoping that the open headers flushed them all out....I only saw the one....maybe he was thinking about making it a home for his family, hopefully the loud neighbors keeps them away!
The truck will possibly be back on the road this weekend, I will have to do a full recon....the last thing I need is a mouse trying to run up my leg while driving.
Old 06-02-2006, 09:30 PM   #6
Americanrider
Everything leaks on my truck, but mouse leaks? Do you have rusted out cab corners?
Americanrider is offline   Reply With Quote
Old 06-02-2006, 10:04 PM   #7
jimfulco
You need a pet snake.
jimfulco is offline   Reply With Quote
Old 06-02-2006, 10:34 PM   #8
fade94
fade94's Avatar
68 short bed driver (71 clip on it now, swapping to 68 when weather cooperates)
67 short step project (will get SWB from the 68)
67 Camaro, #'s matching (my wife's)
03 Dodge Ram 2500 4x4 diesel 5 speed 4.10 rear
fade94 is offline   Reply With Quote
Old 06-02-2006, 10:54 PM   #9
dirtball
dirtball's Avatar
Those little bastards can get through smaller holes than you can imagine. Maybe thru cowl vents or small holes in firewall? I would set a mouse trap in there.
Good luck, Brett
dirtball is offline   Reply With Quote
Old 06-02-2006, 11:27 PM   #10
thewishartkid
thewishartkid's Avatar
The Early bird gets the worm, But the second mouse gets the cheese!
KIDs in the front seat cause accidents,Accidents in the backseat cause KIDs! If it aint short,It aint Sh#t! I like El Caminos
thewishartkid is offline   Reply With Quote
Old 06-02-2006, 11:32 PM   #11
71chevytruckguy
71chevytruckguy's Avatar
couple mouse traps and some posion should do the trick, at least u did find there bones. pulled the tank no my '69 when i first got her and there were a whole lot of dead maggots and some bones behind the tank. chris.
its a work in progess.
71 c-10 lwb, in the middle of frame off restoration.
69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump.
7.807 @ 88.37mph 1.60 60FT
80 g-20 van, tow rig, cammed 305, th350, 10 bolt
88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's
71chevytruckguy is offline   Reply With Quote
Old 06-02-2006, 11:39 PM   #12
Willy Prost
Mice liked the heater core when I first bought my truck.
Must have been a roll of papertowels/fast food napkins lodged in around the core...no wonder the heater was lame until I cleaned it out.
Willy Prost is offline   Reply With Quote
Old 06-03-2006, 06:04 AM   #13
They can fit in,I think,a 1/2-3/4" hole.It`s one of their gifts from God for survival.They have soft little bones.
Old 06-03-2006, 06:56 AM   #14
70GMCer
70GMCer's Avatar
I just removed the outside heater core housing and low and behold, mice had completely filled in the air duct part of the housing and blower wheel with the firewall insulation. I was wondering why my blower was not pushing any air. I'd use a trap rather than poison. Poison will kill them, but a dead mouse can sure stink, and may be hard to locate where the dead rodent is.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 06-03-2006, 08:49 AM   #15
rage'nrat638
i don't think the chicks will dig the dead mouse smell.. try to take them alive
Old 06-03-2006, 08:55 AM   #16
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
When I had my old 1972, my first Blazer, moved from my MIL's house
to mine by a rollback wrecker, about 13 miles, the guy knows me so he
already knew how to get there, I followed him, on the way there five, I
said 5 mice fell out of it from all the bouncing, they were running all over
the rollback trying to find a way off, well they did, and at 60 mph
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 06-04-2006, 01:14 AM   #17
corn
When I brought my 69 home & got it running, I had mice of all sizes shooting out the back sides in both directions. The tailpipes were FULL of them. Hee hee
corn is offline   Reply With Quote
Old 06-04-2006, 08:15 AM   #18
MadDog
1970 GMC
MadDog's Avatar
I haven't had any mice, but my truck sat at my dad's place for 5 years, When i finally got things going again, I had a whole hive of bees in the truck. There are honeycombs everywhere. I have got rid of the bee problem, but i still find honeycombs every once in a while when I'm working on my truck.
MadDog's Website
MadDog is offline   Reply With Quote
