Old 06-03-2006, 06:57 AM   #1
Fasglas
Correct Tailshaft length T-350?...
I have a 1968 Chevy short wheelbase PU with no motor or transmission. I have a 350ci sbc for it now and was planning on using a Turbo 350 transmission. What is the correct tailshaft length T-350 that would have come in this truck?
Thanks!
Chris
Fasglas is offline   Reply With Quote
Old 06-03-2006, 08:29 AM   #2
Sweet72
Sweet72's Avatar
Re: Correct Tailshaft length T-350?...
I have the 6" tailshaft in my '72 swb GMC.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 06-03-2006, 10:44 AM   #3
NewKid
NewKid's Avatar
Good Morning, I think the th400 came in that truck, Why don't you want to use it? It is a far stronger transmission. I think they had some problems with it up until 1978 when they finally got it worked out. Most tranny shops can build out any problem areas. From what I can see is that the th350 with the 6" will be about 9/16" shorter then the th400 - C for overall length. The D length was 33 27/32" and the 13" was 37 7/8" long.
83 GMC Vandura 1 Ton
84 Chevy S-10 4x4 Durango
84 Ford 1 ton Cargo van
NewKid is offline   Reply With Quote
Old 06-03-2006, 04:05 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
New kid is right, the TH350 wasn't put in these trucks untill 69.
However, the 69 - 72 trucks DID in fact have the short shaft TH350.
The TH350 is a perfectly good tranny, and in stock form can handle some heavy use, however, the TH400 is in fact stronger, and if you beat the crap out of your rig, it could be a wise move. The strength doesn't come free though. I can't remember exact numbers, but the kilgore rating is considerably higher on the TH400. (kilgore rating indicates how much power is lost through friction and inefficent designs)
Old 06-04-2006, 10:16 AM   #5
Fasglas
Thanks to eveyone who responded. My main objective is to use as many correct type parts so I won't run into problems with things like a custom length driveshaft. I have two Turbo 350s setting here one has a short tail shaft and the other has a spacer on the tail shaft which makes it longer. I have the driveshaft that came out of the truck and I'm hoping if I use the correct tailshaft length the driveshaft might fit with no mods (the truck had a T-350 in it when it last ran).
Does anyone know how long the driveshaft should be for a short shaft T-350 in a 1968 swb?
Thanks again,
Chris
Old 06-04-2006, 10:36 AM   #6
Longhorn Man
4 foot 10 inches
Old 06-06-2006, 03:14 PM   #7
Fasglas
Thanks again! This forum is great!
