Old 06-03-2006, 09:17 AM   #1
72frmtrk
Question 72 chevy pinion yoke needed
I need a new or good used pinion yoke for my 72 chevy 3/4ton 4x4 truck. It has the big 10 spline pinnion gear. I think its an Eaton rear end, 10 bolt cover. Does any body have one they like to sell or have an idea where I could get one? Mine is grooved out where the seal rides so it leaks. Sadler power train can't get them anymore they are obsolete. A speedy sleeve will not work because the yoke shaft is bigger in diameter than most yokes these days.
72frmtrk is offline   Reply With Quote
Old 06-03-2006, 11:16 AM   #2
Aarons72s
Re: 72 chevy pinion yoke needed
Try some of the larger rear end shopps. There is a company in OKC that might have one called bluementhalls. Or you can post a wtb thread but then you have to spend the 25 bucks to become a subscriber. I hope this helps. Good luck.
Aarons72s is offline   Reply With Quote
