Old 06-03-2006, 04:46 PM   #1
adkphoto
ball joint replacement
Got a 2/4 lowering kit from early classic. Replaced all the rear parts easily since the bed is off: New springs, shocks, panhard bar, shock relocating mounts.
Now working on the front. Replacing the 34 year old ball joints today (in the rain... yeah that's fun).
Anybody have advice on how to remove the upper ball joint.
I've cut off the rivets... now do I just wail on it with a big a** hammer and chisel or is there a more elegant way to get them out?
David
1972 Chevy Cheyenne Super LWB
Chevy Red/White with rally wheels.
Not-so-Stock 350, A/T, A/C, tilt.
Vroom, Vroom....
David Colbert dcolbert@twcny.rr.com
Work hard, play harder!
adkphoto is offline   Reply With Quote
Old 06-03-2006, 05:10 PM   #2
dennislbrooks
dennislbrooks's Avatar
Re: ball joint replacement
Easiest done by removing the upper a-arm. then support the edges and knock it out. You can also use a correct size punch and drive the studs out. A chisel helps sometimes. Best way --- I actually drilled the rivets out.
dennislbrooks is offline   Reply With Quote
Old 06-03-2006, 05:13 PM   #3
ChevyDude
I ground em' down to flat and then you will see the circle outline...choose appropriate punch and with a 3 pound emma....pound them out!
ChevyDude is offline   Reply With Quote
Old 06-03-2006, 07:48 PM   #4
matthufham
as chevydude mentioned on the rivits, and if you can't get the ball joint off the control arms, just hit em with a big fat hammer.
matthufham is offline   Reply With Quote
Old 06-04-2006, 12:14 AM   #5
cornutz
All Praise RANDY!!
cornutz's Avatar
BEAT EM LIKE YOU OWN EM.... cause you do!
cornutz is offline   Reply With Quote
Old 06-05-2006, 08:46 AM   #6
adkphoto
Rivets didn't want to drive out (starting to hate those little buggers). So, Yeah. I beat on those puppies with a BAH and a chisel around the edges until they said uncle.
I took it easy on the first upper ball joint. The second one, I beat the hell out of (took a lot less time that way :-)
No easy way to do this job. But it sure pays off with the fresh feel to the steering.
David
Vroom, Vroom....
Old 06-05-2006, 08:53 AM   #7
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
Air hammer with bull point bit. They'll come right out.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 06-05-2006, 08:54 AM   #8
toddtheodd
The oddest Todd around
toddtheodd's Avatar
isn't that what a ball joint pickle fork is for?
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan
IIOY???
toddtheodd is offline   Reply With Quote
Old 06-05-2006, 09:07 AM   #9
adkphoto
Pickle fork separates the ball joint from the spindle.
Separating the ball joint from the A frames is another story.
D
Vroom, Vroom....
Old 06-05-2006, 10:51 AM   #10
cornutz
All Praise RANDY!!
cornutz's Avatar
I just did this same thing on the 72 burb this weekend... used a big beater and a huge socket that rode the outside of the lower ball joint and some anti-sieze and she slowly listened to me as I talked her into her new home!
Old 06-05-2006, 10:56 AM   #11
ChevyDude
They will come out. Like said above, support the A arm. Position punch appropriately, a few good whacks....they'll be laying on the floor.
