Old 06-03-2006, 04:55 PM   #1
Solver
Solver's Avatar
Engine decoding
Just picked up an engine for one of my trucks today. 350 engine and 350 tranny included.
Guy told me it was an 82 chevy van engine that had 82,000 miles. Told me he drove the van home an hour and it ran great. Got it off the trailer this afternoon and sprayed her down with oven cleaner and high pressure water. Got to checking the front engine pad and came up with a CMJ suffix code. Ran that and came up with this
:1974 CMJ 350 t4OO police - 4 full size
SO much for the 82 theory! really didn't care about year anyway
Any idea whether this is just a regular engine or is it something special for police cars.
Any way the process begins.
Should I put an older style intake on it without all the extra tubes and such , or just plug all the holes up.
Should I convert it over to drivers side alt?
Would you put on a standard thermostat houseing ?
Engine doesn't have to look 1972 stock just wondering what to keep and what to swap out!
any how here is the pics we all seem to crave
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline   Reply With Quote
Old 06-03-2006, 05:26 PM   #2
Sweet72
Sweet72's Avatar
Re: Engine decoding
http://www.nastyz28.com/sbchevy/spcode2.html
Did you go to this site? CMJ was also used on the 1980 305, full size/camaro. I'm wondering what the 1974 t400 police engine was too. What's the block casting number?
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 06-03-2006, 07:22 PM   #3
Sweet72
Sweet72's Avatar
Re: Engine decoding
I also found this information here http://www.chevy-camaro.com/chevy-ca...es.asp?group=2
on that suffix code CMJ
Suffix YR CI HP Main Transmission
CMJ 1975 350 145 4 THM 350/400, federal
Old 06-04-2006, 12:36 AM   #4
Solver
Solver's Avatar
Re: Engine decoding
I am sure it's a 350 not a 305 as the block is the good old 39710 Block
Old 06-04-2006, 01:23 AM   #5
Gray Ghost
Gray Ghost's Avatar
Re: Engine decoding
The 1974 police motor was an 397014 block number and the other good one is the 397010 350. I had the '74 block in the Buffalo when I had it.
Check the number behind the driver's side valve cover, If it's neither of the above, check the nastyz28 site for the code.
The front pad numbers can tell you what it originally came out of.
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
