Old 06-03-2006, 05:31 PM   #1
mudpuppie
mudpuppie's Avatar
headers / ram horns
i have the old ram horns on my 283 , would there be alot or much more power with a set of cheep headers . never ran a set of ram horns before ......
mudpuppie is offline   Reply With Quote
Old 06-03-2006, 05:38 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: headers / ram horns
You'll have ppl tell you that cheap headers are 10 times better than the best manifolds, and all kinds of BS.
However, that's not always true...actually, that specific claim would never be true.
The smaller the engine displacement, and the lower the power level, and the lower the RPMs are... the less headers will do for you.
Cheap headers normally suck. They are a pain to install, they are a pain to work around, they are thin, which makes them louder and shorter lived due to rust, they have crappy surfaces, which leads to more blown header gaskets, and, they simply aren't made very good. Some headers will flow WORSE than manifolds, plus, the ram horns found on these trucks, are some of the best flowing manifolds made.
I say skip the cheap headers... odds are, you'll never be happy with them. This is one area where you really get what you pay for.
Old 06-03-2006, 06:02 PM   #3
mudpuppie
mudpuppie's Avatar
wasnt the 283 a higher rpm engine ?
power mostly on the upper end ?
Old 06-03-2006, 06:22 PM   #4
crazy longhorn
Fabricate till you "puke"
I am a "diehard" header fan, but do agree that cheap in not good here! I do believe that you will pick up some power by running headers/ duals, & a small 4brl carb on your 283. I reccomend Hooker comps $140 through summit or jegs(painted), & they have nice thick flanges & 16 guage tubes. You need to verify the fit with stick shift, but I run a #2452 Hooker on my longhorn. You will want to keep the exaust pipe size down to 2" on the 283, so you dont give up the low end grunt. Add a 1 3/4" H pipe, & a decent set of mufflers(Dynomax super turbos for cheap/good), & set the tail pipes how you like (side exit if you like to HEAR it), or rear exit for more mellow. Again, keep the pipe size down to 2", & add your 3 x 16 " chrome cans to the ends for a deeper sound. A used Edelbrock performer, with a fresh 500, or 600 cfm edelbrock carb should work nice on top. Go for the elect choke versions, as they are calibrated a little leaner(good for the smaller cube eng). You wont find a "magical" extra 100 hp, but you will find some extra spunk from the old 283. best of luck...... L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 06-03-2006, 06:58 PM   #5
Longhorn Man
Some 283 engines were high RPM engines...but not the ones found in trucks. Just like the 327, 396, and a hand full of 350's all had high RPM hardware stock... but again, not in pick ups. (excluding the El Camino)
I'll agree with crazy longhorn, and I had the same headers he is talking about (the price has come down quite a bit) and they were quite nice.
However, I doubt you'll see any improvement from ram horns to headers.
Old 06-03-2006, 07:17 PM   #6
Chevrolet4x4s
Chevrolet4x4s's Avatar
Thinking of Summit brand (Heard they were reboxed Dynomax)headers 18ga $86 +$6 bucks shipping
or Flow Tech 16 ga $104 + 6% tax (lifetime replacement)
Then use the ceramic based VHT header paint.
Which is best?
Shane
1993 K1500 350 5 speed
1985 K10 Silverado Vortec 406 5 speed (in body shop)
"I been drivin' this '85 pickup truck Them buddies of mine call it a bucket of rust She's a little beat up but she still runs like the wind Yeah, kinda like me I been banged and bruisedBeen around the block a time or two But I'm runnin' like new goin' places I never been
No, I ain't broke I'm just broken in"
1963 Dodge Townwagon(its amazng what 30 years and zero miles will do to a vehicle )
Member#20327
Chevrolet4x4s is offline   Reply With Quote
Old 06-03-2006, 08:22 PM   #7
TugOwar
Shane
This header paint readily available or special order stuff?
TugOwar is offline   Reply With Quote
Old 06-03-2006, 10:14 PM   #8
Chevrolet4x4s
Just the 1500(or 1200 can't remember one of the two) degree headder paint in the rattle can their website says its ceramic based or something to that effect I think its like 5 bucks a can
Shane
Member#20327
Old 06-03-2006, 10:17 PM   #9
Longhorn Man
that ceramic paint is ok, but it's not like the ceramic coat you are probably thinkin about. I used it and it worked better than normal spray bomb, but still nothing to write home about.
Old 06-04-2006, 12:56 AM   #10
mocwon
Keep On Truckin'
mocwon's Avatar
Is it a daily driver or a ground pounder? These trucks are not power mongers due to weight, aerodynamics and displacement in the case of a 283.... If you go with headers consider investing in wave-lock washers so you don’t have to keep bending over the fender tightening header bolts. Eastwood makes a great manifold coating if you stay with ram horns.
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 06-04-2006, 01:04 AM   #11
Gray Ghost
Gray Ghost's Avatar
I have run Hedman headers on all my trucks and never had a problem with bolts coming loose. I tighten them very tight once...drive the truck about 20 miles at 60mph or above then retighten if necessary.
I recommend only one brand of header for both fit and finish as well as power. Hedman makes a great set of street headers and Summit sell them for $135 + $10 shipping. The number is 69230...they are 16 ga. and have 1/4" flanges.
I've had bad luck with Hookers on cars [boy that's askin' for it huh?]. They don't fit well and they usually don't last long before rusting out. I have a buddy who owns an exhuast shop in Dallas, he will not install anything but Hedmans.
I've never seen less than a 10hp increase with headers on 350's...not sure about smaller motors though.
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 06-04-2006, 01:05 AM   #12
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
the ramhorns are less problematic than headers,of any brand.Get a nice set of headers if you get them.they are a PITA to change plugs though,and constantly working loose,or at least all my experiances are that way.
For a DD stock/mild engine,I'd stay with ramhorns,just my .02.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 06-04-2006, 07:01 AM   #13
I use headers on everything unless I want it original.Corvette ramshorns look original,yet have larger outlets and are the best manifold to use.I`ve never thought of headers as hard to put on,keep up,or had any leaking problems to sway me away.I hate dealing with donut gaskets on manifolds.I had dual exhaust bent from ramshorns-back on my`71 CustomCamper/20 because it was absolutely a sweet all original,right before leaving for the Grand Canyon.Coming down from the North Rim the right manilfold blew-out,cast iron fatigue.We got to an exhaust shop(Muffler Magic)in Flagstaff and he checked around for a manifold,no luck.He put on "cheap" headers,all he could find.I was using Blackjack AK5000s (aluminum coated) back then,but none were in town.My brand new pipes had to be cut and "doglegged" to fit these cheapo headers,really bugged me.Well,they were on that truck from`89-`03 before I replaced the collector gaskets,only had to tighten the flanges on the heads a couple times,and the black paint was burned off before I got back to Maryland.The truck sat (outside)most of the time and those headers had no paint for all those years.
The first headers I ever bought were cheap.I painted them with VHT and it came back off with the crap-for-paint that came on them,go figure.When I rebuilt the motor a year or so later I sandblasted the headers and sprayed VHT on them.It stuck on them forever,as well as any $200 ceramic-coat job.
Old 06-04-2006, 08:34 PM   #14
71chevytruckguy
71chevytruckguy's Avatar
same here. i recomend flowtech headers, got mine at autozone for $80. did what special-k said above. they've been on the truck for a month and half and no problems. no loosenin flange bolts, blowing gaskets or nothing. and they'll clear the z-bar if you've got a manual tranny. this is on my daily driver.
for spark plug clearance, the best thing i've found are the accel shorty headers plug, they're about 1" shorter than regualr plugs and mak elif much easier with headers, no more breakin plugs when installing them. chris.
its a work in progess.
71 c-10 lwb, in the middle of frame off restoration.
69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump.
7.807 @ 88.37mph 1.60 60FT
80 g-20 van, tow rig, cammed 305, th350, 10 bolt
88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's
71chevytruckguy is offline   Reply With Quote
Old 06-06-2006, 11:41 PM   #15
Chevrolet4x4s
How was the fitment of the flowtechs?How close is it to fitting the exhaust for the manafolds after you cut off the dogleg into the engine compartment?
Shane
Member#20327
Old 06-07-2006, 05:56 AM   #16
Anyone use "shorty" center dump headers on a 4wd which would have had center dump manifolds from factory.I`m thinking this makes a great solution to z-bar issues.
Old 06-07-2006, 09:11 AM   #17
Huck
Huck's Avatar
How do you measure HP gain from headers?? My experience has been that i lost 2 mpg and some significant low end torque with Hooker headers and another 2 mpg from sticking an edelbrock intake on my crate 350. Headers tend to be loud and not necessarly cool sounding.
It's kind of like throwing stuff on a motor to beef up the HP--bigger carb, edelbrock intake, headers--all i've seen is a drop in torque and mpg!!. When I backed them off, the mpg and torque went right back up. According to my engine rebuilder, sticking a different intake and headers without changing the cam is like running premium gas in a stock engine. A waste of money!? Most engine performance shops will tell you the easiest HP gain is from the CAM. You are not getting the bang for the buck with headers. Or course the stock exhaust manifolds do tend to crack and break which is a different problem but just don't expect a quantum leap in anything but noise from headers. My experience~~.
Huck is offline   Reply With Quote
Old 06-07-2006, 12:31 PM   #18
70rs/ss
70rs/ss's Avatar
quote from Huck
Well, yes and no, any one bolt on will not make a night and day deal, but a series of parts will help. Just changing a cam won't do it either unless the heads can flow to the lift of the cam, as well as the intake, carb and exhaust. Changing manifolds for headers will give a small increase, especially if the manifolds are smoggers, (I have a set of BBC manifolds off a 70's 454 with a dimple in the end of the manifold where the four ports converge to dump out, wtf?) headers uncorked that ASAP! In a 283, you are kinda rubbing polish on a turd, but all the upgrades to the 283 can then be transferred to a 327, 350, 383, 400, 406..... So do it, if unhappy, focus on replacing the engine, there is no replacement for displacement, nuff said!
70rs/ss is offline   Reply With Quote
Old 06-07-2006, 03:43 PM   #19
Chevrolet4x4s
I thought that headers were supposed to give you about 2mpg.also tipicaly bigtube headers cause the loss of low end torque but build high end hp.
Shane
Member#20327
Old 06-07-2006, 04:35 PM   #20
71chevytruckguy
fitments real good, clear the z-bar with out an changes. what kinda dog leg are you talkin about? chris.
Shane
Old 06-08-2006, 10:14 AM   #21
Chevrolet4x4s
the dog leg I am talking about is the turn up in the pipe that connects to the dump on the manafold.
Shane
Member#20327
Old 06-08-2006, 03:48 PM   #22
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
My personal favorite is to smooth out a pair of ramshorns, them either have them chromed or ceramic coated (which I am doing).
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 06-08-2006, 09:12 PM   #23
71chevytruckguy
can't tell ya. the exhaust came off a parts truck that had headers with dual runnin all the way back, u cut and re welded them so the dump before the rear tires. chris.
Shane
Old 06-08-2006, 11:34 PM   #24
pumpkin
pumpkin's Avatar
Whole lot of opinions. I love ramhorns, but they are too rare and expensive in my neck of the woods, so I run headers. Cheap way to do duals. I have yet to feel the difference in the seat of my pants,from headers. I used to race hobby stock on a rough dirt track in my younger days, and switched to stock manifolds, cause the track would ripp a set of headers off in half a season of racing. There was no big difference that we found. So there you go, another opinion. If I could get some 2.5" ram horns for cheep I'ld go with them. Nothin says cool like ramhorns.
pumpkin is offline   Reply With Quote
Old 06-09-2006, 08:55 PM   #25
mudpuppie
mudpuppie's Avatar
thaks all , will stick with the rams for looks , and want have to pay for manifolds ...
