Old 06-04-2006, 12:18 AM   #1
skokie
skokie's Avatar
Weird Vibration
I took the truck for a drive today and I noticed when I was at a red light on the way back that I had a vibration coming from the steering wheel while I was stopped. I reved it up a little and it went away. With the truck in gear and brake on the idle is about 550. Not it gear its 750. Truck is a 68 with a 350, qjet carb and 400 turbo tranny. Any thoughts on what this could be?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 06-04-2006, 01:19 AM   #2
Gray Ghost
Gray Ghost's Avatar
Re: Weird Vibration
Got power steering? Check your PS fluid level. Usually hear it more on corners, but I've heard it at idle too.
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 06-04-2006, 02:54 AM   #3
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
Re: Weird Vibration
check all the belts,pulleys,and balancer,make sure everything is good and tight.I have seen this happen with a sheared woodruff key in the balancer.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 06-04-2006, 06:34 AM   #4
70GMCer
70GMCer's Avatar
Re: Weird Vibration
do you have headers. A header tube may be vibrating against the frame at idle. That happened to me, and felt it thru the column.....
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 06-04-2006, 08:48 AM   #5
Botietruck
'71 chevy s.bed/s.side
Botietruck's Avatar
Re: Weird Vibration
Broken/cracked motor mount(s)??
STILL PLAYS WITH CARS...AND TRUCKS!!
Parents! Be good to your kids...they get to choose your nursing home!
250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive!
Botietruck is offline   Reply With Quote
Old 06-04-2006, 10:42 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Weird Vibration
Does it run smooth at idle? We get ppl dropping off vehicles at work with a miss, and at least once a month it is described as front end problems becouse they feel it through the steering wheel.
Old 06-04-2006, 05:27 PM   #7
skokie
skokie's Avatar
Re: Weird Vibration
Well it looked like it just needed some carb adjustment. I put the vac guage on it last night and at idle was getting about 16-17. I richened up the carb 1/2 turn adn up she went to 19. Vibration gone.
68 build thread
