Power steering pump brackets?
Looking to convert my '68 to power steering. Have a "power" gear box ready to go, but need to know what kind of brackets to get for the power steering pump. Have read that there are 2 or more types, based on what kind of water pump you have; "short nose" or "long nose".
Have included pics of my setup, thinking I have "short nose" water pump, but looking for verificataion. Once verified, looking for help with determining the proper brackets; ones that attach to the front of the block/heads or ones that have attachement point to motor mount/elsewhere. Any help would be GREATLY appreciated!!! Thanks, Dave |
Re: Power steering pump brackets?
You have the short pump. You'll need a different set of crank pulleys. I got a 2 groove cast iron pulley and a single groove stamped steel pulley along with the brackets and pump. I'm sure someone here has pics of a correct PS.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. ![]() ![]() ![]() |
3 groove crank pulley (allows to add AC at a later date) , 2 groove WP pulley, 1 groove PS pulley
Hey guys ... thanks for the replies and pics!!!
Do any of you .. or anyone ... have pics of what the P/S pump brackets look like if you have the "short nose" water pump? Do they just attach to the block/heads OR do they have any attachment to the motor mount/elsewhere? ChevyDude, what does your P/S bracket look like and where does it attah to the engine? Thanks again for your help ... Dave |
#5 | |
member #16
![]() Join Date: Dec 1999
This bracket is for small block short pump. There may be more than one type for short pump.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
Thank you both, very much ... just in time and just what I needed to know...
Dave |
The LuvShack Garage
A real pic, not that the assembly one isn't good enough (Left)
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
John, That's the one I was trying to describe.
