Roadtrip!
![]() Join Date: Feb 2003
BIG BLOCKS for sale in MN
Ran across 5 big blocks today in northern mn for sale. Looks like complete long blocks with out accessories. NO brackets, pulleys, alts etc... They are in inside storage. If someone is SERIOUS, i can go check numbers on them and see what they are. He said 402s and 454s. Consider these builders. He is wanting $500-600 each. Must be picked up in northern minnesota. I think the 454s were $600.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Re: BIG BLOCKS for sale in MN
Check the numbers..the Canadian dollars looking fairly close nowadays. Shoot me a PM when you figure some new info.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
Roadtrip!
Rod, it will take a few days before i can get back there, but i will try to find out more. I looked at them today, but i didn't look them over close.
I'd be interested in a 402, if you can get info on one of those. Northern MN isn't far from me.
Thanks...Jim
1967 GMC 1/2 ton 1972 GMC Sierra 1975 Chev 5/4 ton 1978 1/2 Harley FLH 1998 K1500 diesel |
Roadtrip!
I am pretty sure one of them came out of a 71 or 71 chevy truck. The others i'm not sure.
Would you and rod be interested in picking up a couple at the same time? I will try to check them out and get pics on sat. Maybe he will go a little cheaper if i can sell 2 at the same time.
eric i may be interested if he'll go a little cheaper on 2 at a time but would realy like them with pullys and brackets if they could be had
common sense isn't so common anymore |
Roadtrip!
UPDATE: Looks like one is a 70-72 402.
Another is a mid 70's 454 the other one looks like a 73 454. There is also a 400 small block 4 bolt main but i forgot to ask price. There are other misc. heads and intakes, but that is all i saw for complete engines. I think i can arrange shipping to winnipeg for $50 apiece. These have NO brackets or other external parts. They are $500 each. There are also some small blocks in there, but i ran out of time.
Soonest I could run down there would be June 24th to take a look..if there gone by then, there gone.
I don't suppose you have the casting numbers for the 402 block and heads. I would pick it up if I got one, shipping not required.
Jim
Roadtrip!
I didn't pull the valve covers to check those numbers but the block number is 3969854 402
3999289 454 361959 454
Roadtrip!
Rod or whoever may be interested let me know. I can set up a time to look at them and make sure the guy will be around.
Rod, after the 24th will work if i know when. Let me know what works for you.
I'm trying to free some time...but the weekends keep getting busy too.
