06-06-2006, 02:47 PM | #1 |
Full repro floor pans?
Anyone know when these are coming out? Any idea about how big or what areas they will cover? I'm interested to know if they will include the ridge where the front seat mounts to the floor.
'72 K5 CST Blazer 4x4 in perpetual progress '96 2dr Tahoe 4x4 daily driver, Black Bear Performance tune, 285-75-16 Nitto Grapplers, Magnaflow muffler, K&N Air filter, Bilstein Shocks.........E-fan, DT Tri Y or Pacesetter LTs coming soon |
06-06-2006, 02:53 PM | #2 |
67 is sold
Re: Full repro floor pans?
Goodmark told me sometime in June. No real details on what is included except the toeboard will go up higher then the current floor sections do and the frame braces will more then likely be part of the assembly as well
http://67-72chevytrucks.com/vboard/s...d.php?t=195143 |
06-06-2006, 06:11 PM | #3 |
The LuvShack Garage
I heard June also, but don't hold your breath
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
06-06-2006, 07:39 PM | #4 |
The only part that scares me is almost all parts that I have bought or installed have needed some work or adjustment. With a rocker or kick panel patch it is easy becouse you have places you can hide and manipulate the part to fit. Floor sections are ok as well and still take a bit of work but I do not want to think about trying to tweak an entire floor.
Kevin LFD Inc. |
06-07-2006, 07:14 AM | #5 |
67 is sold
Quite a few have used the full floorpans for the 67-69 Camaro that came out a year or so ago. So far things have worked out. Those panels are from overseas, not sure about the truck cab panel.
06-07-2006, 11:17 PM | #6 |
Amen rock, i would think it would just be patch panel material for whatever is missing on your floor that you need. Just cut out that piece and use that. I would hate to cut out the entire floor on a Blazer. Too much flex for me. I replace both halves on my 66 Fastback and than was bad enought leaving the trans tunnel in tact and the section where the rear seats bolt in.
