Some Stuff I Am Taking Off The 72 Gmc F/s
Re: Some Stuff I Am Taking Off The 72 Gmc F/s
![]() Join Date: Apr 2006
hay bill let me know how the inwells are ok when you get thet far thanks dan
dan are you talking about the ft. inner fenders ? if so the drivers side looks good but want no for sure till i take it off. the pass. side is bad.
yes the front inwells ok let me know thanks dan
#13 |
Hey Bill, Do you have a cross support panel, radiator support? I am looking to buy a new one, but thought I'd check out used ones first!! Thanks Jim
#14 |
hey if you want to seperate the proportioning valve let me know . also i need a good 72 chevy steering wheel .
#15 |
![]() c-1072 i have proportion vavles 2wd and 4wd $20.00 shipped to you. |
#16 |
71 GMC 454/TH400
Any eyebrows?
"The bigger you are the harder you fall, the farther you walk the longer you crawl." |
#17 |
I Haven't Found Any EYEBROWS Yet.
#18 | |
#19 |
Hi, I'll take the power brake booster, bracket, master cly and prop value. I'll also need the longer rod as I'm converting from standard to power brakes. Can you give me a quote with shipping to 14304 please?
If you keep and open mind you never know what might drop in. ![]() 1970 Chev C10 SWB, "250 turbo thrift" ![]() |
#20 |
Hey Bill, will you be selling any parts from the bed? I'm looking for the rear wheel housings, particularly the passenger side but would take both if the price is right and they are in good shape. Let me know
Thanks |
#21 |
sgt.booya i will send you a pm.
70chevy4*4nut i will be saleing the bed whole. |
#22 |
I need a 4x4 w/power disk brakes pm me a paypal adress and i will par tonight . I could use this asap so i would greatly appreciate a quick shipment of the part .
Thanks a lot Todd |
#23 |
c-1072 what part are you needing a proportion valve if so i have 1 for a 72 4wd with dis brakes.
#24 |
Not a bad nut after all..
Any exhaust hangers that look like this?
'05 Chevy 2500HD 4x4 '72 GMC LWB 4x2 driver '72 Chevy LWB 4x4 plow truck '71 Blazer 4x4 driver '70 GMC LWB trailer |
#25 |
badpeanut i will check.
