Stock tire size Q
Whats the stock tire size for the C-10
![]() Join Date: Sep 2005
Re: Stock tire size Q
umm i have it wrote some where but i know that the tire are hard to find if you can but it depends on what year the truck is and stuff but i recomend at least a 235/75r15 as a repalcement tire
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
truckdude,
I just want my speedo to be correct. Whats the best tire for that? We have 33 inch on the back right now, and they are making the speedo wrong big time.. when the speedo says 20 i'm going 25 when it says 28 i am going 35 and it goes crazy from there. |
Depends on what stock wheels came with your truck. Sounds like your C10 may have had 15" wheels, originally. My GMC came with 16" wheels and 7.5 X 16 LT bias ply tires. What trans do you have? You can get speedometer gears to correct for larger or smaller tires.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. ![]() ![]() ![]() Last edited by Sweet72; 06-07-2006 at 07:28 PM. |
lt235/75r15 or p235/75R15 XL (EXTRAL LOAD) should put you back on track if you got 15 inch rims its going to be the closest to the oringal tire size i got 255/70r15 on mine and its only off by 3 or 4 miles an hour
I've got the towing package i think, so it has really low gears in the back (witht he big tires it hits about 70.) So maybe i have the lowest gears?
![]() Join Date: Jan 2001
g78 15 original to mine , im now sporting 235 75 15s
damb close ![]() ![]()
2004 Silverado 2500HD Crewcab 4x4 2000 TOYOTA 4RUNNER 1971 CHEYENNE LWB (THE LOVE SHACK) 1967 c-10 lwb (THE FARMERS DAUGHTER) |
Think it was a 7.00 X 15. Not sure but Think it is about a 29 inch tire. Had it on 77.
I got my wheels, and they are 16 by 8 so i guess i'll get a tire to match it. Mostlikely just black lettering.
if its 16's i recomend a 215/85r16 or a 235/85r16
My 70 c10 2wd 6cyl 3spd came with G-78-15 Uniroyal from the factory. The closest size today is 235 75 15. I am sure Coker Tire probably has a replica original type tire if anyone is interested. www.cokertire.com
ongoing 1970 c 10 lwb ![]() 1994 z-28 few mods.-owned since new ![]() 1978 vette silver/grey 25th anniv. paint ![]() |
I rechecked the wheels, they are actually 15 by 7's, heres a pic.
#13 |
okay then i would run a 235/75r15
#14 |
33's fit a 2wd without scrubbing? would they fit on the front? i have a set sitting around so if they would fit that would be nice at least for a while until i get it fully redone.
#15 |
You can still get the G78-15, but it's been changed to 7.8-15 and is a bias ply trailer tire. Some of our small trailers have those and 7.00-15's on 'em. Any bias ply tire will ride really bad in the front though. I had two old 7.5-16 tube type Goodyears on split rims on the front of my truck and they rode really bad, had a lot of vibrations after 40MPH.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
