laying low
![]() Join Date: Mar 2001
pie cutting 69 to 72 hood
Did anybody see the story on this in the current Custom Classic Trucks mag? Gives it the rake similar to the 67 & 68 hoods. I have been waiting to see if some hood supplier would offer a 69 - 72 hood with that 67/68 rake built in. I'd buy it.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
Re: pie cutting 69 to 72 hood
The first one ya saw at a car show would sure throw you off!! Probably looks pretty good.
-Greg My Chevy trucks, past and present: 1962 C10 SB Fleetside 1964 C10 LB Fleetside BBW 1966 C10 SB Fleetside 1966 C10 SB Fleetside BBW 1968 C10 SB Fleetside 1971 C10 LB Fleetside 1971 C10 SB Fleetside 1972 C10 SB Fleetside Cheyenne 1972 C10 SB Fleetside Cheyenne Super 1972 C10 LB Fleetside Cheyenne Super 1974 C20 Cheyenne 1979 K5 Blazer Cheyenne 1982 K10 SB Fleetside Custom Deluxe 1982 K10 SB Fleetside Scottsdale 1986 C10 SB Fleetside Silverado 2008 Silverado 1500 4x4 |
Where's my beer?
What? something like this?
This is a '70 ![]()
Paul How do you make the invisible, visible?.........You take it away. |
i saw that and was disgusted, i love the original hood's look.
#5 | |
Kevin LFD Inc. |
laying low
Yeah Paul. That would be the look! Nice job. I think the stock 69-72 hood is a bit boxey in front and adding that rake really looks good.
laying low
[I get Classic trucks but I have not seen Custom Classic Trucks ]
I get both Kevin. Can't get enough trucks.. ![]()
#8 | |
I have a radical idea!
![]() ***Duck flying objects from 69-70 AND 71-72 lovers!!!***
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
#9 | |
![]() Quote:
Just install a 67 hood on your 69-72 front end. Ghetto here on the board did it and I talked to him at length at what was required and I may go that route too. Looks good in my opinion.
Kevin,
I have the article and I think it looks good but I like the 67-68 front ends. |
#12 | |
More Cowbell....
Worst case, you can drive to Jackson and I will personally take you to Ghetto's shop to show you 1st-hand his work-of-art Burban!
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
#13 |
Insert Title Here
i like the look of the 69-72 better, I actually like how it steps up
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
#14 |
![]() Join Date: Aug 2005
I've thrown this idea around a bit. I have a spare 69-72 hood I've been thinking about experimenting with. In the end I think I'd just go to a full 67-68 clip though.
#15 |
Insert Title Here
is there any way to just take the 67-68 front clip, and modify the grill from a 69-72? Ive never done any type of body work, but it seems a grill would be easier to mod than the rake of a hood
#16 |
Old Skool Club
![]() Join Date: Jun 2001
I like the look that pie-cutting the hood gives to the truck. As to those who prefer the 67-68 front end (cap), I agree that they're cleaner, but the purpose of the change for 69, was to give our trucks a more macho look. The comment came from Larry Bradley, who designed these trucks "back in the day".
So, changing caps to the first-gen would give us a lower profile and that sweet clean look that Mr. Bradley created. Then, there are those of us, who for one reason or another, either prefer the latter style of hood/grille, OR don't want to change it out. So, pie-cutting becomes a possibility. In the magazine, the first thing that had to be done was to mark the cut to be made. Then, you have to remove the inner bracing, under the hood. At no point in the article did it mention re-installing the bracing. So, I wonder if they did. The truck in the article had a 71-72 grille and the hood was a 69-70 version. In the opening pictures, there are two bowties on the front of the truck. My truck doesn't have that redundant bowtie option, though. So, it comes down to getting it done, and even considering creating a mold and doing them up on fiberglass. Thought about. Forgot about it. I don't want to mess with it, but I am sure that someone would be interested. Just add cowl induction, and you're done.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
#17 |
laying low
Right you are my friend. I also am wondering about that inner bracing, whether they modified it and reinstalled or left it out. It would be a floppy hood without it. As pointed out in another discussion of the hood the 67/68 front hood angle almost matches the angle of the windshield and the front isn't quite as boxy. I do like it very much but will not be swapping front caps just to get the hood of my choice. I also don't think I will be attempting to cut my own hood. But that's not to say I might not pick up another used one and take a shot at modding it sometime down the road. I think the 67/68 hood also looks better with cowl induction due to that frontal hood angle. JMO guys.
#18 |
Well up untill yesterday I had never heard or seen this done on our trucks before. But when I sketched out my plans for the 70 2wd blazer I picked up this is one of many body mods that I will be doing.
Ok I found the mag today and all I can say is if you are not real good at metal work do not try this on a good hood! First off in the second paragraph they say "this is a very simple modification." First, You need to remove the entire front structure were your hood brace is located. This is not a fun or real simple task if you plan on re-using both parts. Then you will need to brace the hood back up before cutting your layed out lines other wise this thing will end up all over the place. Have you ever tried to align a hood, not alot of fun but think how much fun it would be if it were to twist even an 1/8" per side 1/4" over all! Those body lines would not endd up so hot. Second, Once the brace is removed and you have re braced the hood allowing you full access to every part of both the inside ond out side you then get to cut 294" of metal with your tool of choise. Keep in mind once you have finished cutting you want these parts to line back up (ya right). Third, Now that it is al cut and you push the hood down you will find that the two edges are no longer ligned up very well. Reason is that as the front of the hood lowers down it pulls back at the same time making for two uneven planes. The sides will do this as well but not as bad tward the front and almost not at all at the rear. So now is when your talents at hammer and dolly work get to come out as you move both edeges tward each other so you end up with a nice smooth but joint to weld. Once the front and side are lined up right you still will need to deal with the radiused angled corner that will need slicing in atleast two sections to work out corectly. Fourth, Start welding in small spots far away from each other. As you do this you will need to hammer the welds to get them to sretch back out since they will shrink from the weld. Note Mig welds do not work and move real well so make sure you get that Tig machine out of the corner and use it for this step. Fith, Once you have finished welding the entire 147" around the hood with out warping things you are ready to slap that brace back inplace and yes this is not an option if you ever want your hood to latch and stay in shape again. Oh i almost forgot you will need to section the same 1 1/2" out of the brace before you re-install it! Verysimple ![]() With that all being said it is not the hardest thing in the word to do just don't think it is any where as easy as the mag made it out to be. This winter I will be doing this on a spare hood that I have and I will do a full write up on how it is done start to finish. Why do I want to do this? Easy I have a 71 SWB with great front sheet metal and a 70 2wd (first year and not real common) with crappy at best sheet metal. When I asked the wife what she wanted to do with them she chiose the 67-67 front end (I have a nice front 68 end in the attic) for the 71 SWB and she wanted to keep the 70 looking as a 70. So although it wil look like a 70 down to the 6 lug rims it will have every panel tweaked in some direction or another. Most people would not even pick up on most of the mods unless their was a bone stocker side by side to it. I like the look of the 67-68 front ends but I do not want two alike and I do not want this blazer to be a bolt on queen. That is why, you may like it or you may not but I get to say that I did it ![]() Kevin LFD Inc. Last edited by Rokcrln; 06-08-2006 at 07:43 PM. |
#19 |
Seems like it would be a whole lot easier to just re-shape the front lip of a 67-68 hood to fit behind the 69-72 outer grille.
#20 |
IF Customs did it on this 70. Its toward the bottom.
http://www.ifcustom.com/projects/pro...s-t/travis.htm
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo |
#21 |
I realy like the 67-68 hood line, and I just picked up a 72 Blazer that had one 68 fender on it,,,,,it got me thinking. Why can't a person just cut the extra inch and a half (ther abouts) extra length out of a 68 hood, weld a strip of metal in and call it done. It looks like it would work. Anyone tried it? This is the front of my 72 c20 with the 13000 lb. gvw overloads.
#22 | |
So am I nuts for liking alot of work for small visual changes ![]() Kevin LFD Inc. |
#23 | |
A guy with a truck
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#24 |
A guy with a truck
Looks like that's what they did here. Notice how there is no rib running down the center of the front slope.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 06-09-2006 at 11:19 PM. |
#25 |
A guy with a truck
Found another: username- ghetocrewser
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 06-09-2006 at 11:21 PM. |
