FarmBoy.
opinions please??
hey guys, long time lurker here. i've come to a cross roads in my project.
its a '69 K20, getting a '67 front clip. however, the front axle is a wee bit messed up. leafs at the wrong angle, a shackle being bent. along with the front driveshaft needing a new CV, and needing new tie rod ends. along with brakes, etc. so, this is where i began thinking. should i swap out a 2wd frame? i have a '67 1/2 ton, and a '68 3/4 ton for frames. right now my project only consists of a running gears, rad support, and cab on frame. so, it wouldn't exactley be a terribly hard swap. could i get some opinions please? this is just a hair brained idea that i ran past my dad, and i'd like some extra input. thanks! .sam. |
Re: opinions please??
I'm a 4X4 guy, so,ooooo, what are you? If four whell drive isn't important to you then do whats easiest, and cheepest. If you like the four by, then you know what to do.
4.56 with lockers front and rear, dana 60 front, Eaton rear 6" lift 35" tires, nice street truck, that will wheel ![]() |
