Old 06-08-2006, 11:58 PM   #1
poorboy
poorboy's Avatar
Dually conversion
I'm starting a new project. I want to take a 71 with coils and conv it to leafs. Is there a refence point for the hangers? I have an 84 dually as a donor. Will the 1 ton frt end bolt in like a half ton? Thanks for the info.
poorboy is offline   Reply With Quote
Old 06-10-2006, 09:34 PM   #2
Olden Days
Living In The Past
Olden Days's Avatar
Re: Dually conversion
welcome poorboy,
the front xmember will bolt in like the 1/2 ton conversion. Cant help you on where to put the spring hangers other than to say find a 1 ton and measure, or roll that sucker under there, line it up, square it up, make sure you driveline from the 71 can still bolt up within tolerance and then drill. I dont know if you were planning to use the 84 springs or not but it should be noted that they are not the same length as the 71 chev/gmc. The 84 springs will be longer. If i was you I would try and find the correct hangers and springs. The mods to the 84 rear would be simple enough. The perches will line up with the springs, but you will need to cut off the shock mounts and relocate them, and may have to get a longer brake hose and/or tweak the brake hardlines a little.
Olden Days is offline   Reply With Quote
Old 06-11-2006, 02:00 AM   #3
poorboy
poorboy's Avatar
I think for the rear I'll get a spring perch for the rearend and use it to set up the hanger locations. Should be a fun project. It's going to make a nice rig to tow my racecar.
Old 06-11-2006, 04:16 PM   #4
67_C-30
I have a radical idea!
67_C-30's Avatar
Welcome poorboy!! You have come to right place. There lots of dually lovers here. Check out the link below. We have been putting together the biggest known collection of 67-72 Dually pictures for quite awhile now. Please post pics of your project when you get 'em! Good luck with your project.
http://67-72chevytrucks.com/vboard/s...d.php?t=126946
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
