06-09-2006, 02:05 PM | #1 |
91 Burb Starter wires
I have a 1991 Burb with 5.7L Installing starter and need wiring directions to complete. Have four wires to connect to M, R, and S Have tried several ways and seem to have either a short or a wrong connect as the batt cable when hooking up will spark.
06-10-2006, 08:08 AM | #2 |
Re: 91 Burb Starter wires
It shouldn't spark when hooking up the battery cable. Are all the ring terminals the same size? You should only have one wire going to the S terminal...that is to energize the solenoid. I can't remember what all the other wires are for. Good Luck
06-10-2006, 03:49 PM | #3 |
Still having fits with this. I have a wire coming off of the Positive Post of the Battery (second to the Battery Cable itself) If I leave this unconnected then the starter will crank. However I also have no electricity to lights and even the fuel pump. It has a small ring connector so it will not connect to the Large Post on the Solenoid and if connected to the S terminal it causes a spark when connecting the Battery. Still stumped
06-11-2006, 04:43 PM | #4 |
FYI Main Battery cable goes to the Solenoid. Secondary one goes to the Generator. The Solenoid then has two cables connected to the M terminal and one small wire connected to the S terminal. The Suburban RUNS !!
06-12-2006, 10:43 AM | #5 |
Congrats...Electrical problem will drive you crazy . At least you have it going now.
06-12-2006, 12:35 PM | #6 | |
yeller
Congrats on getting it running...starters and wiring them drives me crazy! (past bad luck/experiences)
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
