06-09-2006, 07:23 PM | #1 |
Rearend out what to do?
The rear is out on my '68 3/4. Violently shakes the truck and making noise. It has coil rear so I think its going to be hard to find a replacement. Will a half ton fit the mounts? Gary in okc
06-09-2006, 07:30 PM | #2 |
its all about the +6 inches
Re: Rearend out what to do?
yep, it'll fit, but it'll look silly.
Where are you located? What kind of rearend do you have? |
06-09-2006, 07:35 PM | #3 |
Im in oklahoma city. I just need it drivable again so my wife dosnt try to bury it. Rear is sort of visable here. I got wacked, parked, by a garbage truck in that corner in december and I think the high miles and four foot skid might have done it in
06-09-2006, 07:39 PM | #4 |
Better pic. Im talking to the right guys that I love this truck
06-09-2006, 07:46 PM | #5 |
I'll assume the garbage truck ppl gave you some compensation... I'd call there insurance comapany and point out the rear is locking up now.
You have the Dana rear in there. If that's a big block truck, (dana is very common in big block trucks) then you'll play hell getting another one with the same gearing that'll bolt right in. However, a 3/4 ton rear shouldn't be hard to locate. You're best bet may be, paying the $25 fee and subscribing to the board, and then posting a wanted to buy thread in the parts pages. There's enough members within 100 miles of you, I think you'll find what you need fairly quick. I know you are new, and may not know how good this place is when you are in a pinch, but you won't get a larger audiance looking for a rear end anywhere els but here. The other boards are good and all (some of them anyways) but the numbers are here. |
06-09-2006, 08:06 PM | #6 |
I'll probably have to scrape up the money and do that.
06-09-2006, 08:18 PM | #7 |
collector of vintage rust
Thats a shame, the bed looked fairly rust free on the bottoms. Just like a timex. Takes a lickin, and keeps on tickin! Wish ya luck finding parts. You couldnt have found a better board, or got a reply from a better person who knows what they are talkin about!
06-09-2006, 09:13 PM | #8 |
are you sure it's the rear and not the driveshaft?? bad ujoints and or carrier bearing
06-09-2006, 09:18 PM | #9 |
Cantankerous Geezer
Best solution is to replace the rear end. Measure the distance between the wheel mounting faces on the drums and go to the junkyard. You should be able to find a 14 bolt full floater and weld your mounts on it. Don't know what gears you have now, but 3.73s are usually an easy score.
It does appear that you have a 12 bolt Dana. Sad to see one of them go out.
Fred There is no such thing as too much cam...just not enough engine. |
06-09-2006, 10:07 PM | #10 |
I replaced the ujoint forward of the pinion. It was way bad. I jacked it up and ran it in gear and it sounded like the rear was pretty noisy. Its definatly rough when you roll it through by hand. I may still pull the rear shaft and listen to the carrier. Plus Ive jumped on it pretty hard and no ujoints broke
06-09-2006, 10:10 PM | #11 |
Thanks Fred. The rear isnt going anywhere. I still have the 396 that was in it too (454 now). Ive considered the mount remount. I figure getting the differential looked at down the road is more realistic if the truck isnt waiting for it
06-09-2006, 10:22 PM | #12 |
Happy to be here
Pull the inspection cover and see what it looks like inside. If your not sure, post pics and we can give you an insight on what wrong.
06-09-2006, 11:19 PM | #13 |
"Ochre Ogre"
Stock factory gearing behind the 396 would have been a 3.54 and the Dana 60 just like you have there(10 bolt cover by the way). Any other gear ratio was special order. If you were closer I would have what you need out in the shed, but you would have to put up with the PowerLoc differential.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
06-09-2006, 11:48 PM | #14 |
Still drivin' a Rat Rod
I'd start by yanking thing apart,maybe you just have a busted spider gear,or something that can be fixed fairly cheap.
Also just about any chevy rear will prolly fit,just the brakes,and drums will be different,so don't narrow your search to just the 5 years.I swapped a 3rd member from a 79 into a 72 1/2,and it fit no problem,both 14 bolts,same thing inside.So I would guess the same is true with the 3/4 tons.
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
06-10-2006, 12:08 AM | #15 |
A mechanic at a carlot I worked at claimed it to be 4:10 posi after changing an axle seal once. Im second owner btw. It was literally a farmer I knew. Manual everything bigblock. Its low geared enough that I almost cant drive it on the highway.
But the cool part is that a buddy just called and thinks he has one for partial trade on a vibratory shaker partswasher I have that we've been trying to get a deal going on. I love this truck and driven it daily since '93. And you know I love my truck because my backup Last edited by garyj36; 08-24-2006 at 10:29 PM. |
08-24-2006, 10:34 PM | #16 |
Hey, I did some more checking on this truck today and pulled the rear driveshaft. When I turned the front driveshaft through by hand the front ujont fealt fairly rough. But the pinion on the rear fealt real rough. Is it possible I just have a munched pinion bearing making it shake? It had a wasted u-joint in front of it a long time. Also, I checked and the rear is full of oil. Truck has 275,000 known miles btw( I'm second owner). I also lit both back tires two feet forward and reverse after it warmed up, so it seems like the gears must still be good
08-24-2006, 11:01 PM | #17 |
Come to think of it, is there anyone in okc that knows these trucks and can help me figure it out?
