Old 06-10-2006, 01:05 AM   #1
wild one
Registered.........
wild one's Avatar
Help for 1966 chevy panel? *edited by mod*
Hello everyone, I am new to this board and hope I am posting in the correct area. I have recently aquired a 1/2 ton 1966 chevy panel. The gas tank is leaking and I was wondering if one of the under the bed conversion tanks would bolt in in place of the original.
wild one is offline   Reply With Quote
Old 06-11-2006, 11:28 AM   #2
Fred T
Cantankerous Geezer
Fred T's Avatar
Re: Help for 1966 chevy panel? *edited by mod*
Welcome to the board. Since your thread could have been read as a wanted to buy, I removed that portion. To post wtb, you need to post in the parts boards, which requires a paid subscription. Subscribe here This is a result of abuse by some. It helps pay expenses and gives you more benefits.
To view parts available from vendors go to
http://67-72chevytrucks.com/vboard/a...t.php?f=6&a=10 .
The parts you are looking for are available as reproductions.
As for the fuel tank, the kits will work, but usually require some work to install. I know from experience that GMC Pauls will be able to answer your question about what has to be done to install the tank in your truck.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 06-15-2006, 06:18 PM   #3
Vaughn
Leaking from where?
If you just have a gas smell in the cab, without a specific location for the leak - it is probably the rubber portion of the gas filler tube. You can get a new one from the online places or get one (rated for gas, not a radiator hose) from Napa. I've bought one from Napa before, so I know they carry it. You may have to "convince" the counter guy though.
Vaughn is offline   Reply With Quote
