Old 06-10-2006, 01:52 AM   #1
gregbr
Senoir Member
gregbr's Avatar
WTB: Adjustable drag link for 67 4wd
I will be needing an adjustable drag link, steering linkage between pitman arm and axle steering arm, for my 67 4wd. It has the closed knuckles with a manual steering box currently. I want to add power steering but the current linkage is not adjustable. It also has a different axle arm than the open knuckle type. Maybe someone has already done this and can tell me what I need. I have a power steering box and drag link from a 72 4wd. Greg
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4"
70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010
70 GMC Restoration Pictures
http://67-72chevytrucks.com/gallery/...00&ppuser=4424
gregbr is offline   Reply With Quote
Old 07-06-2006, 05:58 AM   #2
gregbr
Senoir Member
gregbr's Avatar
Re: WTB: Adjustable drag link for 67 4wd
ttt
Old 08-01-2006, 06:05 AM   #3
gregbr
Senoir Member
gregbr's Avatar
ttt
Old 08-09-2006, 01:25 AM   #4
Livrat
Member #1049
Livrat's Avatar
Greg.. Are you still in need of the adjustable steering link?
Let me know I may be able to help you out.
Mark
Livrat is offline   Reply With Quote
Old 08-10-2006, 12:35 AM   #5
gregbr
Senoir Member
gregbr's Avatar
I have the needed parts on the way....hopefully it's all I need. Thanks.
Old 08-12-2006, 10:56 PM   #6
gregbr
Senoir Member
gregbr's Avatar
As usual I deleted my PM's then need to ask someone a question. I just received a ball joint (part of linkage between steering box & axle steering arm) from a board member. It fits the 67/68 closed knuckle axle steering arm and screws into the adjusting sleeve from a 72 setup to make a shorter linkage. The previous owner of this ball joint bought it new, and I would like to know what it is from in case I need another one. P.O. just PM'd me, not listed in this thread. Greg
