5spd tranny nv3500 cheap
this tranny came from an 88 1/2 ton truck tranny shifted good around 100k 200.00 open to offers or trades . i need a good blk dashpad and steering wheel for my 72. pics upon request .
SUPERscrapMAN
Re: 5spd tranny nv3500 cheap
HOw hard woudl it be to swap this in place of a 700r4?
Christine 1987 Chevy S10 2.8l 5 speed 600k miles! still chugging along - wifes ride Old Smokey 1990 Chevy K1500 Suburban 6.2L Diesel - Banks sidewinder The WarBeast 1994 Chevy Suburban K1500 - Semi retired at 400K miles The BLueOx 1994 Chevy Suburban. K2500 454 Used on a daily basis. ![]() ![]() |
not at all hard you would need all the pieces what year truck you running ? if its 88 and up i have all the parts if its 87 and down you will need to come up with a clutch pedal for the hydrolic type clutch system .i think your original cross member will also work .
SUPERscrapMAN
How much would you take for all the parts to make it work I have a 90
I would give it all to you for 200.00 but shipping would be around 100.00 i am just guessing but it could be that much . the flywheel is just about as heavy as the tranny .
SUPERscrapMAN
Just so I am sure here. We are talkingabout the tranny, clutch, clutch cylinder, clutch pedal, flywheel shift lever. and all associated bolts and other junk to make it work. If you can find out a exact shipping price I am very interrested. I haul a lot of weight in my truck and I am hard on 700r4s I though I mitght try a 5 speed and see how it behaves
SUPERscrapMAN
oh yeah and the crossmemember. ONe other thing.do you know if the auto driveshaft will work ot will I need one as well
i have all the parts except the nuts and bolts . you might want to just buy a new clutch slave and master slave cylinder .as for the driveshaft i can check that i have the 5spd shaft and 700r4 i can do some measuring for you i think the tranny crossmembers are the same .
SUPERscrapMAN
Ok let me know what you find out
Is this out of a 4x4, and could you take the bell housing off and put a older one on to get a manual clutch, pics also please.
07 Chevy classic LBZ Duramax (a few mods) '67 Chevy 1/2 ton 2wd (in pieces) '69 Chevy 1/2 ton 2wd (on hold) '71 GMC 3/4 ton 4x4 ‘71 GMC 1/2 ton 2wd suburban |
no its a 2wd
Oh,you can't buy that new
![]() Join Date: Apr 2000
curious, how much to send it to 08070.?
"been there, done that, ruined the T-shirt". 2007 LBZ GMC Sierra, ECSB 2006 LM7 RCSB Silverado 98 Vortec project. 94,3500,6.5L 4L80 81 SWB GMC POS finally gone ![]() 73 Pinto, stock, w/CragarSS's-eww ![]() LOTS of Cummins trucks. |
#13 |
do you still have the NV3500?? If so I'd be interested in the trans. only. I am currently running one, but its on its way out....
1985 GMC Sierra 1500, 1/2 ton, 2WD, LWB, TBI 305 5 speed, 3.42 rear 2007 GMC Sierra 1500, xtended cab, 4X4, flexfuel 5.3L 1999 BMW 528i |
