Old 06-10-2006, 05:45 PM   #1
MJN
MJN's Avatar
Need Help! Correct P/S and A/C brackets-pics please
Anyone have pictures of correct stock power steering and A/C brackets on a 350? I'm having a hard time finding all the correct brackets to make the pulleys line up with each other. I have double groove pulley on the water pump, double on the power steering pump and a triple on the crank. I'm starting to think the water pump is incorrect but everthing lined up before I put the stock A/C compressor on it. The compressor and brackets came off a '80 GMC with a 350 but I didn't grab the power steering brackets. Any help would be appreciated.
BTW- this is on a '74 chevy k/20 with a 350 engine.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 06-13-2006, 12:56 PM   #2
MJN
MJN's Avatar
Re: Need Help! Correct P/S and A/C brackets-pics please
Ttt
'17 GMC Yukon XL
VCCA member #58596
Old 06-13-2006, 02:05 PM   #3
Slonaker
Insert Witty Text Here
Slonaker's Avatar
I don't know how much this will help, if any at all, but check these photos out. They are from my '86:
http://slonaker.net/images/truck/ac_brackets/ac1.JPG
There are about 23 photos. Just keep changing the file number in your browser... ac1.jpg, ac2.jpg, ac3.jpg, etc.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 06-13-2006, 03:21 PM   #4
method2mymadnes
method2mymadnes's Avatar
On which side of the engine is your AC compressor?
method2mymadnes is offline   Reply With Quote
Old 06-13-2006, 04:40 PM   #5
MJN
MJN's Avatar
Slonaker- THanks for the pictures but I have the older style compressor (long black one). I'm not sure if it makes a difference in the bracketry though. I know the compressor brackets are different than yours. THanks
Method2mymadness-Mine is in the stock position on the driver's side above the power steering pump.
Old 06-13-2006, 07:28 PM   #6
magnethead
7000 #'s of american IRON
magnethead's Avatar
see if these help any...it's a 454 but i would think (but i'm known to think wrong) the belts go to basically the same places, assuming your engine is not smog equipped.
magnethead is offline   Reply With Quote
Old 06-14-2006, 08:47 PM   #7
MJN
MJN's Avatar
magnethead- thanks for the pictures but only those from a small block will work because I mainly need pics of the correct brackets. I'm having a hard time getting the correct brackets on the power steering pump. THanks again.
'17 GMC Yukon XL
VCCA member #58596
Old 07-03-2006, 12:19 AM   #8
MJN
MJN's Avatar
Anyone else have pictures? I'm still trying to make it work, I have about 8 different sets of brackets now and still can't get the power steering to line up and now the A/C compressor isn't lined up with the intake manifold bracket. This weekend I'll be at the Iola Old Car Show on Friday so hopefully I can find something there too but anything will help.
'17 GMC Yukon XL
VCCA member #58596
Old 07-04-2006, 03:37 PM   #9
AspecialZ
Street Rod Restoration
AspecialZ's Avatar
been there
hope these help
Follow me on Instagram @ hot_rod_shop
AspecialZ is offline   Reply With Quote
Old 07-04-2006, 09:33 PM   #10
MJN
MJN's Avatar
Thanks guys but I got it figured out. The power steering pump wouldn't straighten out, so I went to the junkyard and I stumbled over a front half of a '74 K/20 with the motor still sittin in the frame and it had every bracket with compressor still on it. So I grabbed the compressor, power steering pump and all the brackets I could with all the hardware too. Well, the power steering bracket that bolts to the water pump was missing a small spacer between the pump and bracket, which is behind the pulley. So all I needed was a little spacer and it's all fixed now. I took all my brackets off and put all the junkyard ones on so it's a matched set now and it all lines up perfectly. I even got lucky and it had the v-belts rusted into the pulley grooves so now I have belts to compare to the new ones I have to buy. Thanks again guys!!
'17 GMC Yukon XL
VCCA member #58596
Old 07-04-2006, 09:59 PM   #11
krue
Designated A-hole!
krue's Avatar
That's the best way to do it.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
