Old 06-10-2006, 09:41 PM   #1
Nate003
swapping a 68 A/C heater box over to non-A/C
What all is involved in swapping over an AC heater setup to a stock non-ac heater setup? can i just swap over the the box with the core, motor, and fan, or does the whole inside under-dash setup need to be swapped out as well?
Nate003 is offline   Reply With Quote
Old 06-10-2006, 10:38 PM   #2
neonlarry
neonlarry's Avatar
Re: swapping a 68 A/C heater box over to non-A/C
New insides plus different holes in firewall.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 06-11-2006, 12:12 AM   #3
Nate003
could you tell me how differant the holes in the firewall are? so what is the best solution if i have a a/c cab but don't have any a/c?
Old 06-11-2006, 06:17 AM   #4
JimKshortstep4x4
Swapping out your AC would be quite a job if done properly. The AC has a good heater setup and will work fine if the AC is not hooked up. Is there a reason that you want to swap it out?
Here is a pic with AC holes and non AC holes in the firewall that one of the members posted a few years ago.
Jim
Old 06-11-2006, 05:09 PM   #5
Nate003
i was going to do it for the simple fact the non ac box looks less cluttered inside the engine bay. looks like i'll be sticking with the ac box tho. thank you.
