Old 06-11-2006, 06:56 PM   #1
Free88
Free88's Avatar
How to clean the headlights on a 91
Read here in the forum before about cleaning the headlights in these trucks. Could someone please point out the link to me so I can give cleaning mine a try? I can not find the link. I know it has to do with different grits of sand paper and such. It is to clean the yellowish film off. Thanks.
1986 Silverado Short box fleet side. project
2005 VW Tiguan 4 Motion
1997 Blazer S10 4x4
1990 Chevy Silverado K1500 Extended long box
Free88 is offline   Reply With Quote
Old 06-11-2006, 07:03 PM   #2
C-10volvo
C-10volvo's Avatar
Re: How to clean the headlights on a 91
if you dont want to use sand paper, yoy can always use some rubbing compound
Ken Morgan
For fun: 1964 Volvo 122
For slow: 1984 Chevrolet C-10
For everything else: 1997 BMW M3
C-10volvo is offline   Reply With Quote
Old 06-11-2006, 10:19 PM   #3
Russell
Professional Grade
Russell's Avatar
I just ran mine through the dishwasher Mine wern't badly yellowed though.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 06-12-2006, 06:02 AM   #4
mbgmike
I have sanded them, used rubbing compund and polished them on a buffing wheel.
We have experimented with several of these kits you buy that make all kinds of claims and our opinion is save your money. The last one was making all kinds of fantastic claims. It is a two part system. And claimed it was a proprietary formula The first part smelled just like 3m buffing compound and the second was clear coat polish.
mbgmike is offline   Reply With Quote
Old 06-12-2006, 08:06 PM   #5
Free88
Free88's Avatar
Thanks guys, much appreciated. Someone had at one time a step by step procedure write up on how to do this. I can't remember how long ago but I am hoping someone will remember. Thanks
1997 Blazer S10 4x4
Old 06-13-2006, 03:46 PM   #6
STEVE A WILBURN
I Used 1500 Wet Sandpaper And Put A Buffing Wheel On My Drill With Red Compound, And Then Put On A Good Wax Still Looks Good.
Steve
JUST HAPPY TO BE ALIVE.
STEVE A WILBURN is offline   Reply With Quote
Old 06-16-2006, 07:41 PM   #7
JohnO356
I copied this off a site (Can't remember which one) a long time ago:
1. When wet sanding, dip the paper in clean water often. You can also re-wet the lenses during the sanding process using a spray bottle.
2. Using straight horizontal strokes, wet sand the lenses with 400 grit wet/dry sandpaper to remove all deep pitting and even out the lens surface. If you have heavy pitting or severe clouding/yellowing, start with 240 grit. It will save you a lot of time and elbow grease. This phase is complete when all of the deep scratches and pits are removed. They should be very hazy at this point but consistently hazy.
3. Follow up using the same process but graduating through 600, 800, 1000, 1500 and 2000 grit paper. Depending on availability, you can skip some of the grits but it might require more sanding with the grits that you choose. They should be looking good now...shiny when wet but very hazy when dry.
4. Using a fine rubbing compound, buff the lenses to a nice smooth finish. Buff again with plastic polish following the instructions that come with the product. Meguire's PlastX and Novus will work well to polish them to a like new appearance. Try to use a polishing product that contains a UV protective finish.
A simpler way though is a cleaner sold on Amazon.com called Plexus. I've used it and it works well.
JohnO356 is offline   Reply With Quote
Old 06-17-2006, 12:06 AM   #8
Free88
Free88's Avatar
Joh, thank you that's the article I was looking for. Maybe I will try the Plexus as you mentioned. Thanks to all.
1997 Blazer S10 4x4
