Old 06-11-2006, 09:09 PM   #1
fade94
fade94's Avatar
I need 3 drive shaft measurements, please?
All are for SWB with small block.
1) Long tail TH350
2) Short tail TH350
3) TH400
Also, what are the measurements for the actual transmissions? I know I have a TH350, however, I don't know if it is a long or short tail.
68 short bed driver (71 clip on it now, swapping to 68 when weather cooperates)
67 short step project (will get SWB from the 68)
67 Camaro, #'s matching (my wife's)
03 Dodge Ram 2500 4x4 diesel 5 speed 4.10 rear
fade94 is offline   Reply With Quote
Old 06-11-2006, 09:34 PM   #2
farmtruckIII
71 GMC 454/TH400
farmtruckIII's Avatar
Re: I need 3 drive shaft measurements, please?
My big block and turbo 400 drive shaft measures 68" center joint to center joint. The short shaft 350 tail shafy should be around 6" I think. I can get some exacts on that tomarrow.
"The bigger you are the harder you fall, the farther you walk the longer you crawl."
farmtruckIII is offline   Reply With Quote
Old 06-11-2006, 09:54 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
a small block with a short shaft TH350 in a SWB truck would be 4 foot 10 inches.
Old 06-12-2006, 07:17 PM   #4
farmtruckIII
71 GMC 454/TH400
Here is a bad pic of a short shaft 350
Old 06-13-2006, 04:30 PM   #5
RicksTrucks
RicksTrucks's Avatar
I measured my two piece on my 69 - I have a 350 eng with TH-350 tranny that has a 6 inch tail. The front shaft was 25 inches from center to center and the rear is 35 center to center.
68 Short Stepside C-10
69 SWB C-10
70 Flatbed C-20
70 LWB C-20 BB402
70 LWB C-10 CST
70 LWB C-10 CST
71 Short Stepside Cheyenne C-10
72 LWB C-10
72 Blazer 4x4 4spd
95 Jeep Cherokee 4x4
RicksTrucks is offline   Reply With Quote
Old 06-13-2006, 04:42 PM   #6
clif1968
Junior Member
clif1968's Avatar
A TH400 is around 29" long.
Clif
'68 C/10 LWB, 327, TH400, 12 bolt
clif1968 is offline   Reply With Quote
