Old 06-12-2006, 09:32 AM   #1
ratfreak88
Cabfloor Q....
Hi all, I've been looking all over for a part to replace the part of the cab floor that is tied into the cab corner and the rocker panel and sits on the rear floor support. Surely someone else has had to replace this
ratfreak88 is offline   Reply With Quote
Old 06-12-2006, 09:39 AM   #2
hambone1958
hambone1958's Avatar
Re: Cabfloor Q....
I think they call that a dog leg. Did you check gmcpauls.com or mothertrucker.com or calssic industries.
Alan
hambone1958 is offline   Reply With Quote
Old 06-12-2006, 10:02 AM   #3
ratfreak88
Re: Cabfloor Q....
yeah checked all of them, no luck
Old 06-12-2006, 12:26 PM   #4
Green Machine
Green Machine's Avatar
Re: Cabfloor Q....
One of these ??? Try www.manestruckparts.com
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 06-12-2006, 12:48 PM   #5
ratfreak88
Re: Cabfloor Q....
hey green machine, does the piece in the bottom pic go all the way to the back of the cab and behind the piece in the top pic? if so then yes that is what i need
Old 06-12-2006, 01:00 PM   #6
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: Cabfloor Q....
Try wes at classic heartbeat I am sure he has em...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 06-12-2006, 01:40 PM   #7
BigSky71
LAIDOUT
BigSky71's Avatar
Re: Cabfloor Q....
If you are referring to that section of floor just inside the cab corner, I had to make my own piece for that area. I think I used some of the cutoffs from the front floor pan, bent it to shape and welded it in, no tough to do. They might make a piece for this area, but I didn't find it when I ordered my new metal.
67 2wd Shorty
Build Pictures
BigSky71 is offline   Reply With Quote
Old 06-12-2006, 01:57 PM   #8
ratfreak88
Re: Cabfloor Q....
BigSky, that is exactly the peice I'm looking for. I can't beleive nobody sells them
Old 06-12-2006, 02:32 PM   #9
BigSky71
LAIDOUT
BigSky71's Avatar
Re: Cabfloor Q....
I suggest that you work installing the other replacement pieces first, and by the time you get to this back floor piece you will certainly have the skills to cut and shape the right chunk of metal!
67 2wd Shorty
Build Pictures
Old 06-12-2006, 09:33 PM   #10
Sgt.Booya
Sgt.Booya's Avatar
Re: Cabfloor Q....
You can get this for $299.95
But if you floor is really gone it might save you some work. Its a newer product offering from this year from Goodmark Industries.
http://www.goodmarkindustries.com/HomePage.html
If you keep and open mind you never know what might drop in.
1970 Chev C10 SWB, "250 turbo thrift"
Sgt.Booya is offline   Reply With Quote
Old 06-12-2006, 10:01 PM   #11
Bob D
Rolled on Paint Club
Bob D's Avatar
Re: Cabfloor Q....
The lower pic in Green Machines post is the part you are looking for: rear cab floor patch. It is missing in the pic below, waiting to be welded in. I mistakedly got them from LMC, and they were as thin as tin foil. Got a new pair from GMC Paul and they were heavier gage. The passengers side has the indentation for the jack to rest in.
Bob
1970 GMC 1500 swb fleetside
SB 355ci.
Smog heads
Summit 1102 cam
Performer intake and carb.
Finally in about 1 piece in the yard.
Bob D is offline   Reply With Quote
Old 06-12-2006, 11:29 PM   #12
Southpa
Southpa's Avatar
Re: Cabfloor Q....
I pieced mine together with 14 ga. scrap steel. Worked like a charm.
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 06-13-2006, 01:48 AM   #13
ratfreak88
Re: Cabfloor Q....
bobd the lower pic in greens post looks like it doesn't wrap around the back side of the rear pillar. southpa i pieced mine together also but it didn't turn out as well as yours. sarge!!! man i dont really need a whole floor pan but man that is cool. i kep hearing goodmark is making these but your the first to post a pic and price, i couldn't even find it on their website. that may be the way i go for that price
Old 06-13-2006, 02:34 AM   #14
1000000to1
1000000to1's Avatar
Re: Cabfloor Q....
Bob
I have heard from a guy I know that year one has crappy light sheet metal too. Sometimes you can get lucky and find a good donor truck to cut parts out of cheaper than buying aftermarket.
2013 avalanche 5.3l
1971 Gmc 350 1958 Gmc fleetside
1000000to1 is offline   Reply With Quote
