front driveshaft removal
how do you remove the front drive shaft on a 70 3/4t.....I am pretty sure its the dana 20 transfer case if that makes a difference. I was under there yesterday, I thought that it was a slip yoke.....but it doesn't wanna slip off
1969 SS 350 Camaro Sold 2008 1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's ![]() 1980 Chevy Malibu 2 dr Sold 2007 1993 Olds. Cutlass Ciera Wagon Traded 2006 2003 Saturn L200 w/5pd. D/D My list spans 5 decades with One common thread.....GM! |
Re: front driveshaft removal
There are four bolts coming in from the back (t-case) side of the output flange on the t-case that hold the shaft to the flange. They are very hard to get to (it can be done) without removing the crossmember first. I am sure that you have an NP205, not a Dana 20.
Tim |
Aluminum slot wheels rule...
I just wedged my arm up in there and went at it with a stubby wrench. A good thing to buy to do this would be a ratcheting stubby wrench. The bolts are a pain to get at.
