Old 06-14-2006, 05:17 PM   #1
see ten
WTB this ad
see ten's Avatar
Drop spindles won't turn to the right! Help!
Ever since I lowered the C10 is doesn't want to make right turns. It is fine going down the road but if you are trying to cut into a parking spot in a lot where the spots aren't angled... LOOK OUT! I have to back up a time or two to get it in there. I came to a 4 way stop today having to turn right with a van sitting on my right and I thought I wasn't going to make it. I have already gotten under the truck and had my wife cut the wheel all the way to either side and I can't see anything hitting. I had read a thread a while back about this and they were talking about trimming the spindle or the control arm but I can't see mine hitting anywhere. Am I missing something here? Somebody help me out here!
see ten is offline   Reply With Quote
Old 06-14-2006, 05:50 PM   #2
Oldtruckfanatic
Truck junkie
Oldtruckfanatic's Avatar
Re: Drop spindles won't turn to the right! Help!
Did you jack the truck up by the suspension or the frame? (not an insult just asking) you have to have the suspension loaded to see where the contact would be. I haven't run into this problem yet so I can't help with what to trim unfortunately. It's also a good idea to make sure the steering box is centered.
Oldtruckfanatic is offline   Reply With Quote
Old 06-14-2006, 06:19 PM   #3
see ten
WTB this ad
see ten's Avatar
I had her on the ground when I checked it. The steering box turns about a 1/4 turn less to the right than it does the left.
Old 06-14-2006, 06:42 PM   #4
It doesn`t sound centered.How is the turn signal canceler?When using the right blinker,does it want to click off real easy?Like when turning a little back to the left to correct?
Old 06-14-2006, 06:52 PM   #5
see ten
WTB this ad
see ten's Avatar
There aren't any problems with the turn signals. Everything seems tip top until I get ready to cut into a parking spot or those 4 way stops in small streets. The box is an Early Classic Enterprises quick ratio unit. When we installed the box we turned it from left to right and counted the turns and centered it. I spoke with Terry(?) from ECE a while ago and he suggested disconnecting the tie rod on the right side and see if the wheel will turn any further. It's too hot and I'm too tired for that right now but I guess I can try that next.
Old 06-14-2006, 07:01 PM   #6
Oldtruckfanatic
Truck junkie
When the steering box isn't centered 1/4 turn is where the double notches are in the splines on the shaft so it may not be centered. If it's not contacting anything I would turn the steering lock to lock and count the turns then go half of that back and see what you get. if the wheels are turned to the left you may have to center the pitman arm again. maybe even try the lock to lock thing while jacked up to make sure it doesn't turn more when it's unloaded. (remember to use jackstands)
Old 06-14-2006, 07:15 PM   #7
see ten
WTB this ad
see ten's Avatar
Hmmm, If I recall I had the front end jacked up with the drivers side wheel off when the box was installed........... Could the droop of the suspension caused me to be out of center when I put er back on the ground? If so how am I going to get the steering wheel, box and everything else straight again without having to align it?
Old 06-15-2006, 01:49 AM   #8
Oldtruckfanatic
Truck junkie
Sometimes the droop can get things off a little but I have also gotten new or reman boxes that wern't centered when I got them. I have also thought I had them centered and somehow moved them when putting the pitman arm on. Basically I'm just trying to help with some stuff to check but I'm definitely not saying this is the problem without a doubt. Hope this helps a little.
Old 06-15-2006, 12:28 PM   #9
lolife99
67-72 parts collector,…
lolife99's Avatar
Seems like there is a difference in steering stop location on the lower control arm. Maybe the 67-68 being different than the others? Maybe someone can chime in. Maybe I'm just dreaming,...
Keith
Convert to disc brakes.
Old 06-15-2006, 12:44 PM   #10
see ten
WTB this ad
see ten's Avatar
Still stumped!
Old 06-15-2006, 01:20 PM   #11
Hart_Rod
Hart_Rod's Avatar
This may be off base, but when making a left turn, it will appear sharper than making a right turn due to the driver being in the left seat. If you have a dirt area that you can drive the truck (a place that will leave tracks), mark a line in the dirt for a reference point, turn the wheel a 1/4 of a turn and do a 180 (hold the wheel at a constant position). Put the truck back at the same spot and do the same thing but in the opposite direction. Then you can measure your radius of turn and see if they are the same.
Hart_Rod is offline   Reply With Quote
Old 06-22-2006, 08:18 PM   #12
mikeoj
I will add my two cents here since I've kinda been there before.I don't recall you saying a year.Anyways.Check to see if your drag link(the linkage between the idler arm and the pitman arm) is hitting the crossmember.If it is,take it off and turn it around!Don't ask how I know this!It's a clearance issue.You may have other issues to!OK,I'm done now. Mike
69 Lwb C-10 402/700R4
70 Lwb C-10 250/3pd
Wisc.
mikeoj is offline   Reply With Quote
Old 06-24-2006, 11:18 PM   #13
72MARIO
72MARIO's Avatar
Dont ask me either......... I had to pay for 2 front end alignments. The tires will howel when turning sharp and the turning radius will suck. On a positive note it coronered really good.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
