Old 06-15-2006, 12:44 PM   #1
bagged69c10
soon to be bagged64sub
bagged69c10's Avatar
What do I need to steer with a Z'd frame?
I am in the process of Zing my frame and I figured some of you more knowledgable guys might be able to give me some insight on what I need to buy.
1969 c-10, bagged, Zd, 20" Boyds SOLD!
1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726
1965 c-10 long bed
1993 Sierra x-cab
1999 tahoe-4/5 on 22s
2005 Chevy work truck
bagged69c10 is offline   Reply With Quote
Old 06-17-2006, 03:00 PM   #2
bagged69c10
Re: What do I need to steer with a Z'd frame?
So nobody on here has a Z'd frame with borgeson joints?
1965 c-10 long bed
1993 Sierra x-cab
Old 06-17-2006, 03:34 PM   #3
dwcsr
Hollister Road Co.
dwcsr's Avatar
Without pics or measurements or something to go by its kinda like asking how high is up and what do I need to get there. What are you using for steering box, shocks, frontend, A arms, etc... A steering joint is a given with almost any frame mod. even then we need to know what type of steering shaft you are going to use before anyone can give you that info, they come in D, DD, square, various splines, slip, solid and so on. Post a little more info on what your doing and what you have so far. Then it will be easier to give you some acurate info.
dwcsr is offline   Reply With Quote
Old 06-17-2006, 07:29 PM   #4
7deuce
Sold! 2 days after finished
7deuce's Avatar
I JUST spent 275.00 on the 3 joints and a DD shaft. The column is a 3/4 36 spline to DD then youll need a DD to DD then a DD to 3/4 30 for the P/S box. Id count the # of splines on your Box b/c I used one off of a later chevy. Other than that the DD shaft and a 3/4 heim joint. Thats all.....lol The SH!T NEVER ENDS.......INDY OR BUST
7deuce is offline   Reply With Quote
Old 06-18-2006, 11:41 AM   #5
bagged69c10
Thanks 7 duece, gives me a little somewhere to start.
I z'd it 3" with stock control arms. Im not sure what the steering column came out of cuz its a tilt with the ignition in it. Also not sure of the steering box. If anyone has any pics of their steering shaft it would be a great help.
1965 c-10 long bed
1993 Sierra x-cab
Old 06-18-2006, 04:48 PM   #6
mike nutt
69fatmotor
mike nutt's Avatar
my truck is z'd 3" and i'm running the stock steering shaft , it is close but there is clearance. i've included a picture (the red circles mean nothing) my truck is not bagged
mike nutt is offline   Reply With Quote
Old 06-18-2006, 08:22 PM   #7
dwcsr
Hollister Road Co.
dwcsr's Avatar
I forgor about thie link. it has a lot of good info.
http://www.classicperform.com/TechBo...ngTechTips.htm
