06-15-2006, 05:36 PM | #1 |
Front sway bar on a 4wd
I went looking for a set of corp 10 bolt spring plates for my swap, when I did I noticed that they have a sway bar attached to them, has anyone done this upgrade? Is it worth it? Does the cross member for the sway bar bolt up directly?
1969 SS 350 Camaro Sold 2008 1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's 1980 Chevy Malibu 2 dr Sold 2007 1993 Olds. Cutlass Ciera Wagon Traded 2006 2003 Saturn L200 w/5pd. D/D My list spans 5 decades with One common thread.....GM! |
06-15-2006, 08:40 PM | #2 |
20' Daredevil (Ret)
Re: Front sway bar on a 4wd
Can't answer your question, but as usual I do have an opinion! I am a big fan of swaybars for highway use, especially if you (A) tend to corner enthusiastically, or (B) sometimes carry large heavy loads. But I don't like 'em on 4WD trucks, if they are used off-road. Kills some of the suspension flex that you need over uneven terrain. Off-road guys will often use quick-disconnect end links so they can undo 'em for trails, and hook 'em back up for the road.
06-15-2006, 10:08 PM | #3 |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Put a sway bar in my 71 Blazer.
Here's the link to it in the FAQ section. http://67-72chevytrucks.com/vboard/s...d.php?t=140216
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
