06-15-2006, 05:43 PM | #1 |
wtb: 78-86 4wd spring plates 1/2 or 3/4t
I need the front spring plates off of a corp 10 bolt axle. These are the parts that the front u-bolts run through. Not sure if I can use the sway bar and cross member or not, but please give me a price for with and without those parts.
Shipping to 48198 would also be appreciated. Thanks
1969 SS 350 Camaro Sold 2008 1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's 1980 Chevy Malibu 2 dr Sold 2007 1993 Olds. Cutlass Ciera Wagon Traded 2006 2003 Saturn L200 w/5pd. D/D My list spans 5 decades with One common thread.....GM! |
06-16-2006, 02:40 PM | #2 |
Re: wtb: 78-86 4wd spring plates 1/2 or 3/4t
i looked at both my trucks and cant see where the corp 10 bolt and dana44 spring plates look any diff i have some from dana44 axles. i have used the 10bolt plates on 44s. let me know if you want a set of dana44 plates $40 plus the ride.
06-18-2006, 08:54 PM | #3 |
Born Psycho
just a little FYI, there are two different axle tube diameters on dana 44s and the plates are not interchangable between the two. the tube sizes are 2 3/4 or 3 inch. not sure on a 10 bolt tube diameter. i found this out the hard way so hopefully it'll save you some trouble, i built a dana 44 from end to end and then found it was a "big tube 44" and i had a hell of a time finding plates that were affordable--at that time the dealer wanted about $200.00 for the pair.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
06-19-2006, 08:24 AM | #4 |
mike, you have a PM.
Jerry, I too figured this out the hard way, my 70 had the smaller diameter axle tubes, which is why I find myself in the current situation I am in....I measured the tubes at 2 15/16" but had my u-bolts bend to 3".....so I guess thats a good thing, (I already checked, the fit perfectly).
06-19-2006, 11:55 AM | #5 |
i went out for a walk in my yard today and of the 20 dana 44 axles i put the tape on i only found 2 that are 2 3/4 all the rest are 3 inch. the 2 small axles are both under blazers so was it a blazer only axle?
06-19-2006, 02:24 PM | #6 |
my axle was under a 3/4t truck, but it was a 1970, I figured it was probably an upgrade that came with the 71 model year?
