06-15-2006, 07:04 PM | #1 |
I need pics please,what are these clips for?
I had my 402BB engine rebuilt and I have 3 clips that I don't remember where they go , I believe they go on the oil pan somewhere. 1-clip is metal and 2 1/2 inches long and has one bolt hole at one end and at the other end has 2 u shaped clips like to hold a line or something and the other 2 clips are the same, 2-inches long and one bolt hole at one end and u shaped with rubber at the other end like to hold a line or wiring? Can someone please tell me where they go or take some pics. Thank you very much.Dave
06-15-2006, 07:59 PM | #2 |
Oilfield Trash
Re: I need pics please,what are these clips for?
Sounds like they are the clips that bolt on the pass side of the oil pan and hold the tranny cooler lines in place.
14 Dodge 3500 Mega Cab 08 Dodge 3500 Mega Cab 87 Chev 3+3 4x4 80 GMC K10 High Sierra bone stock 70 Chevelle 350SS long term project 68 GMC 3ton Grain Truck/Garbage wagon 50 Pontiac 2 Door Coupe Project "I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr. |
06-15-2006, 08:13 PM | #3 |
all 3 or the 2 that are alike or just the one that is alike and where on the oil pan do they bolt on? Thank you.Dave
06-15-2006, 08:32 PM | #4 |
Oilfield Trash
Dave, cant help you out on exact location, but i can tell you the one with the rubber might be for your battery cable to the starter, the other 2 should be the tranny line holders, i am away from home right now so thats the most i can tell you
06-16-2006, 08:27 AM | #5 |
New Member
This picture shows the tranny cooler lines bracket placement on my really greasy 71 350. The other smaller bracket is for the starter wiring, if I remember correctly. Not sure about the third bracket, if you post a picture of it I'm betting some one will know where it goes.
71 Cheyenne, SWB, K10 |
06-16-2006, 09:31 AM | #6 |
Thank you guys,sorry I don't have a digital camera. Thank you 78 Bronco the picture you posted which takes care of the one bracket.I just need to find out where the other 2 brackets bolt up ,which are the same which are u-shaped and have a rubber coating on them and 2 inches long and have 1 bolt hole in them. Thank you very much. Dave
06-16-2006, 09:38 AM | #7 |
another?, I have a turbo 400 which there is a smaller and a larger metal line does the larger or smaller one go in the bracket you have pictured or does both lines go into the bracket? Thanks again.
06-16-2006, 08:03 PM | #8 |
New Member
Both my trans cooling lines are the same size and they both fit in the bracket.
Do any of these brackets look like yours? Two of them had the rubber or vinyl type coating on the before they were cleaned up.
06-17-2006, 05:08 PM | #9 |
The other 2 brackets I have are the same with the rubber coating on them which are like the bracket you have in the middle.Do you know where they bolt up and know what they are used for? Thankyou again 78Bronco.Dave
06-17-2006, 06:18 PM | #10 |
New Member
Mine only had one of those. You can see where it was located if you look at the greasy engine photo. Just below and to the left of the engine block drain plug on the oil pan flange. It held the battery cable that goes to the starter.
Sorry I don't have any clue in regards to the second one you have. I'm sure someone else on this site will be able to help you out.
06-18-2006, 08:35 AM | #11 |
Thankyou 78Bronco for your help. I sure appreciate all of your help and the pics.Dave
