Old 06-15-2006, 11:47 PM   #1
dboyzalter
dboyzalter's Avatar
whats the difference in 67-72 and 73-87
4x4 suspension? I thought the rear was different somehow... but I don't know how... just wondering because I am thinking about getting some 73-87 blazer rear leaf spring mounts and putting them on my 71 K10...
and when I do this should I get the 73-87 lift kit? or does it matter??
dboyzalter is offline   Reply With Quote
Old 06-16-2006, 12:30 AM   #2
89 crew
Re: whats the difference in 67-72 and 73-87
The things that will matter are, the width of the leaf springs, the size of the head of the center bolt in the springs, and blocks if you are using them. One other thing you want to pay attention to is the size of the u bolts that come with the lift kit. I have never found a kit that came with the proper size. If you are using blocks I would recomend buying them without the bolt kit then find bolts with the proper diameter. For that see http://67-72chevytrucks.com/vboard/s...d.php?t=202576
89 crew is offline   Reply With Quote
Old 06-16-2006, 03:06 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I think the 73 - 87 ones are longer too... which would require new/relocated pertches on your frame.
Old 06-16-2006, 04:23 PM   #4
73-87 leafs are mounted further apart on the axle. Leafs are diofferenc size also. Best bet would be to cut the mounts off your 72 axles and weld them onto the newer axle. then use all the 72 hardware (leafs ect). Get the lisft kit for the 72.
Old 06-17-2006, 12:25 AM   #5
dboyzalter
dboyzalter's Avatar
yeah but my rear leaf spring mounts are messed up... like there is a massive rust hole threw it... and only the front and back remain... there is no middle... and they are all off my truck as of now... see link in sig for details...
Old 06-17-2006, 01:03 AM   #6
89 crew
If you are using blazer parts I would keep the lift lit to match the doner.
Old 06-18-2006, 09:18 AM   #7
My answer to your question is,"about a year."
Old 06-18-2006, 09:45 AM   #8
wibilly
wibilly's Avatar
how much of a lift are you going with? i have a 69-72 blazer frame with a 10" lift and much more will be listed on parts board as soon as josh gets my money and gets me set up
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 06-21-2006, 10:57 PM   #9
dboyzalter
dboyzalter's Avatar
So I think the 73-87 2 wheel drive 3\4 ton rear leaf spring hangers are the same... anyone know for sure?
Old 06-22-2006, 07:49 PM   #10
dboyzalter
dboyzalter's Avatar
maybe not... checked today... close though...
