Old 06-16-2006, 12:09 AM   #1
outlawchevy
outlawchevy's Avatar
6 lug rim ?
will 6lug rims off of a 96 tahoe 4x4 work on a 69 1/2 2wd truck thanks for any help ? the rims are 17 but i dont knoe the back spacing
(If all else fails get a bigger hammer)
outlawchevy is offline   Reply With Quote
Old 06-16-2006, 03:07 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: 6lug rim ?
center hole is too small. you can hog it out, but then the back spacing is way off. Get some off a 2 wheel drive, and they'll only look 1/2 stupid. (back spacing is closer to being right)
Old 06-16-2006, 04:59 PM   #3
Blazer1970
Blazer1970's Avatar
Re: 6lug rim ?
In other words, they can be made to "work", but they will not fit.
Blazer1970 is offline   Reply With Quote
Old 06-16-2006, 05:08 PM   #4
72 Cheyenne402
72 Cheyenne402's Avatar
Re: 6lug rim ?
I have some 17" off my 05 Silverado will they work?
1972 Cheyenne 402 LWB
2005 Silverado X-Cab 5.3L
2004 John Deere L120 20HP B&S
72 Cheyenne402 is offline   Reply With Quote
Old 06-16-2006, 05:16 PM   #5
Zumo
Hot Rods For Life
Zumo's Avatar
Re: 6lug rim ?
Dood I was thinking or putting my 4x4 ralleys on my 04 Tahoe. Hahahaha!
1968 C10 LWB ****SOLD***
Andy
Viva Los Bicicletas!
Los Muertos Custom Bicycles
Zumo is offline   Reply With Quote
Old 06-16-2006, 05:20 PM   #6
Re: 6lug rim ?
They work (and look) great going that way Zumo. I used the newer style center caps on mine.
72 cheyenne 402....same thing...the newer wheels have too small a center hole and way too much backspacing.
Old 06-19-2007, 05:20 PM   #7
grayw0lf
Re: 6lug rim ?
It sounds like the late model Toyota 6 lug rims are a better fit than Chevy's are for our older 67-70 trucks.
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 06-19-2007, 05:58 PM   #8
Musclerodz
Re: 6lug rim ?
Center bor is too small in those as well
Mike Redpath
Musclerodz is offline   Reply With Quote
Old 06-19-2007, 06:00 PM   #9
NONHOG
NONHOG's Avatar
Re: 6lug rim ?
Might be better but "not just right" mine are plain jane Tundra wheels only
because they were free but they work for now
check em out
I'm still trying to figure center caps out cause the Toyota stuff would look
like crap !
"I feel the need for speed!"... as soon as I am done with my nap.
NONHOG is offline   Reply With Quote
Old 06-19-2007, 08:17 PM   #10
grayw0lf
Re: 6lug rim ?
Does anyone know the ideal specs? Centre bore, backspacing, offset, etc...
05' Dodge Neon
94' Seadoo SP
Old 06-20-2007, 08:30 AM   #11
grayw0lf
Re: 6 lug rim ?
I guess a better question might be, what are the best fitting wheels for the 67-70 trucks to fit over aftermarket disc brakes?
05' Dodge Neon
94' Seadoo SP
Old 06-20-2007, 09:24 AM   #12
1970shortbed
Active Member
Re: 6 lug rim ?
i believe that if you have disc brakes front and rear then any 6 lug wheel off todays full size truck or tahoe/suburban will work just fine
if you have disc front and drum rear like me then u will need to get wheels with the bigger center because the small center wont fit over the axle/drum in the rear
i just did this with mine and they fit fine
if u have one of those places that sells all kinds of wheels take yer truck there and try a few different wheels watch the width of the rear wheel so it does not hit the inside of the wheel well
i have 2 inch drop spindles and springs in the front and rear is stock height and i have in the front 275/45-20s with a few inches clearance and in the rear 285/50-20s with a spacer because the drivers side rubbed the inside of the wheel well a very little ( i never checked b/s and offset before i bought make sure u do )
1970shortbed is offline   Reply With Quote
Old 06-20-2007, 11:29 AM   #13
djw32
Re: 6 lug rim ?
1970 Shortbed,
Do you have any pics?
djw32 is offline   Reply With Quote
Old 06-20-2007, 12:00 PM   #14
1970shortbed
Active Member
Re: 6 lug rim ?
Originally Posted by djw32 View Post
1970 Shortbed,
